September 06, 2026, 09:29:16 am
I am looking at picking up the 202mx (https://focusattack.com/pushbuttons/popular-brands/crown/sdb-series/30mm/202-mx/) Crown buttons as my main action buttons. These are .110 connector buttons.However, trying to find black player buttons all seem to come in .187 connectors. Using an Ultimarc iPAC4, what is the recommended wiring to support both connector types with since all my other buttons will be .110. Thinking specifically things such as the ground daisy chain, and wiring.Is this standard that most cabinets have to support multiple connector sized buttons?
Quote from: max.r.mccarty@gmail.com on June 10, 2020, 05:33:38 pmI am looking at picking up the 202mx (https://focusattack.com/pushbuttons/popular-brands/crown/sdb-series/30mm/202-mx/) Crown buttons as my main action buttons. These are .110 connector buttons.However, trying to find black player buttons all seem to come in .187 connectors. Using an Ultimarc iPAC4, what is the recommended wiring to support both connector types with since all my other buttons will be .110. Thinking specifically things such as the ground daisy chain, and wiring.Is this standard that most cabinets have to support multiple connector sized buttons?Just buy the .110 harness and change the ones you require for .187.You wont get a harness with both unless its custom built.
