Author Topic: Rock ola 477 gripper arm problem  (Read 3080 times)
Harry477
  • Last login:June 01, 2020, 11:03:41 am
« on: June 01, 2020, 11:03:41 am »
Hi, I have a Rock Ola 477 Jukebox. The Gripper Arm is not picking up after the record has played. The problem is that once the record has finished the curved arm rises up by about 10mm before closing to grip. Therefore is misses the record and grips just above it, then goes through the motion of raplacing it but without the record.
Any clues how to solve this problem please ?
whammoed
  • Last login:May 22, 2026, 03:03:47 pm
  • Crack don't smoke itself
    • NiceMite
Re: Rock ola 477 gripper arm problem
« Reply #1 on: August 31, 2020, 04:37:33 pm »
Could just be that the old grease has hardened or gotten sticky.  That mechanism needs to be moving freely to work properly.  You may just need to clean and re-lubricate the problem area.  Hard to say though for sure without seeing it in person.
