Author Topic: Help wiring a RGB momentary pushbutton to Pacled64 and PC  (Read 1446 times)
Negativecreep0
  • Last login:November 28, 2020, 10:59:49 am
« on: May 20, 2020, 12:50:57 pm »
Hey guys I would like to use this RGB momentary pushbutton in the diagram its 5v common anode (+) to turn my pc on and off but I would like to control the RGB with the pacled64 controller like the rest of my cab will be controlled. Can anyone edit the included diagram to show me what I would connect where to complete this circuit. For those unfamiliar the pacLed64 is a led controller with common anode(+) connections. Thank you (I would like the led light to come on when the pc is on and off when off)
  • Last login:Today at 03:50:26 am
Re: Help wiring a RGB momentary pushbutton to Pacled64 and PC
« Reply #1 on: May 20, 2020, 04:16:01 pm »
Here you go.   ;D
Negativecreep0
« Reply #2 on: May 21, 2020, 08:05:49 am »
Thank you Scott. I guess I was overthinking trying to figure out how to have the LED only turn on when pc is on and off when pc is off but when the pc is on I guess the Pacled64 would be on and when it is off the power to the pacled64 is off also hence not powering the LED!  :cheers:
