Author Topic: WG 2575-U4GS27J problems  (Read 1210 times)
steveslotty
  • Last login:May 15, 2020, 08:30:24 pm
« on: April 16, 2020, 10:50:47 pm »
I have a wells gardner k7500 U4GS27J. I cant seem to get it to work. I have no power basically. Its not clicking like when its tring to restart. I have changed the electro csps, flyback, hot, ic101, ic701, ic702, d101,d102,d103,d104, q101, most of the over 1watt resistors i have 4 yet to change i will do tonight, i also made sure the neck pcb was the correct one for a k7500. You know all them have slightly diffrrent capacitor and q501 setups.
I was thinking since i got this monitor not working if its supposed to have a pincushion pcb to work? Its a 25" monitor but it says u4gs27j on model number. Does that mean 27"? The monitor tube and pcb is together from factory as best i know. I have no experience with pincushion pcbs i have never worked on a monitor with one.
