Author Topic: anyone know how to disassemble a european wico (similar looking to omni stick)  (Read 925 times)
GroovyTuesdaY
  • Last login:June 07, 2005, 03:22:18 am
  • "Follow the white rabbit! ....KNOCK KNOCK NEO...."
I'm pisses lol.  Anyone know how to disassemble an omnistick? I bought it off ebay and it was labeled as a european wico.
The retaining ring is not like happs at all.  Its the kind that has 2 little special point nose pliars holes that need to be used to open outward.  Unforunatly i dont own a pair of those and i wanted to make sure that i am even disassembling right.
thanks,
groovy~
In the mighty words of the BEE GEES im-
"STAYIN' ALIVE, STAYIN' ALIVE!"
hehehe
RandyT
  • Last login:Yesterday at 05:23:14 pm
    • GroovyGameGear.com
You need a ring spreader with the right size pins for the little holes.  Alternatively, you might be able to use a very fine pair of needle-nose pliers made for electronics.
And you probably are disassembling them right.  Pull that clip and the stick comes apart.
If you really get frustrated, just grab ahold of it and bend it out.  But you'll have to replace it with a properly fitting E-clip (because the old one won't be worth anything afterwards).  ;D
RandyT
