Author Topic: RGBcommander log error  (Read 2631 times)
Mytha
  • Last login:September 15, 2020, 10:08:22 pm
« on: April 06, 2020, 07:58:14 pm »
I've been trying to set up retroPi for a while now, the issue I'm having is that when i boot up a rom the lights in my buttons are supposed to change to match that roms settings. Instead the default animation that runs when the frontend is active is the only thing i get. The software that controls the lights is called RGBcommander, i'm using an ultimarc I-Pac UltimateIO board. Here are the logs that rgbcommander gives me when i run it but i don't understand/can't find help on this error message.
06/04/20 16:37:50 [DEBUG] [processMonitorWorker] starting processMonitorWorker
06/04/20 16:37:50 [INFO] [startListening] selectserver: listening on IP 0.0.0.0, socket 10
06/04/20 16:37:50 [WARNING] [startListening] selectserver: bind failed, error: 98
06/04/20 16:38:06 [INFO] [RGBAstart]random animation chosen -> Pattern30_32
06/04/20 16:38:06 [ERROR] [connect] failed to claim interface nr 3 -> LIBUSB_ERROR_INVALID_PARAM
06/04/20 16:38:06 [WARNING] [connect] assuming UIO non gamepad enabled firmware - retrying
06/04/20 16:38:07 [WARNING] [fadeSpeed] ULTIMATEIO_1 fadespeed set to  0 -> FAILURE
06/04/20 16:38:07 [WARNING] [setOff] setting ULTIMATEIO_1 -> fadeSpeed(0) -> failed
06/04/20 16:38:07 [INFO] [setRGBAspeed] RGBA Pattern30_32 speed set to 100
06/04/20 16:38:07 [INFO] [RGBAthread] rgba Pattern30_32 play back start at speed 100
Can anyone help me?
lrdfoo
  • Last login:February 26, 2021, 02:50:22 pm
Re: RGBcommander log error
« Reply #1 on: February 22, 2021, 11:43:17 am »
did you ever get any assistance with this?
i'm installing RGBcommander for the first time and i'm just starting to troubleshoot the issues are similar to yours.
pi@playbox4:~$ tail -f /usr/sbin/rgbcommander/rgbcmdd.log
22/02/21 16:37:02 [INFO] [mamefifo] starting sdlmame monitoring thread
22/02/21 16:37:02 [INFO] [mameNetworkCommunicator] mameNetworkCommunicator started
22/02/21 16:37:02 [INFO] [processMonitor] awaiting FrontEnd (emulationstatio) start...
22/02/21 16:37:02 [INFO] [rgbcmddMsgQueue] starting rgbcmdd message queue thread
22/02/21 16:37:02 [DEBUG] [processMonitorWorker] starting processMonitorWorker
22/02/21 16:37:02 [INFO] [startListening] selectserver: listening on IP 0.0.0.0, socket 10
22/02/21 16:37:02 [WARNING] [startListening] selectserver: bind failed, error: 98
22/02/21 16:37:03 [INFO] [RGBAstart]random animation chosen -> Pattern34_32
22/02/21 16:37:03 [INFO] [signalHandler] interrupt signal (11) received
22/02/21 16:37:03 [ERROR] [signalHandler] invalid access to storage raised - terminating now! - unable to exit normally
^C
lrdfoo
« Reply #2 on: February 23, 2021, 05:30:54 pm »
I figured out my issue... you have to put a _1 after ULTIMATEIO
as soon as i added that mine is working
