Author Topic: Rowe Crestwood Jukebox - Very low volume on the left channel  (Read 2532 times)
Giz11
  • Last login:April 07, 2020, 12:03:49 am
« on: March 26, 2020, 02:41:25 am »
Hi All, I have a Crestwood Jukebox and have discovered the left channel is not working properly. If I disconnect the right speakers and sub I can very faintly hear a very tinny sound coming from the left speaker. . I have swapped left and right inputs into the amp and the left is still faulty. I have taken the amp out and nothing seems burnt out. The balance control does not seem to work either. When turned full left sound still comes out of the right speakers. The amp is a R-2179A. I have connection from the test RCA plugs to a home theater system and only the right channel can be heard. Any help would be much appreciated.
Ken Layton
  • Guru
  • Technician
Re: Rowe Crestwood Jukebox - Very low volume on the left channel
« Reply #1 on: March 31, 2020, 04:33:37 pm »
What's a Crestwood? Please use the model number from the plate on the rear of the jukebox so we will know what machine you have.
Giz11
« Reply #2 on: April 07, 2020, 12:02:43 am »
The AMI Crestwood is a CTI-1. It has a R-2179A Amp
