Author Topic: Unable to pull a log file  (Read 2626 times)
Vectorfire
  • Last login:October 30, 2025, 11:32:59 am
« on: February 12, 2020, 04:24:17 pm »
I'm having a couple of issues, and following the instructions on the groovymame page to pull a log file before making a post I have not been able to do so.
Seems straightforward enough.
Instructions:
Code: [Select]
c:\mame_folder>groovymame.exe romname -v >romname.txt
for me and Street Fighter 2 thats:
Code: [Select]
c:\GROOVYMAME\mame64 sf2 -v >sfv.txt
The game starts and when I exit out I have a text file named sf2, but it's empty.
Doesn't matter which rom I try.
Any ideas?
Groovy_Mame Rig:
Windows 7 Home Premium
Intel i7-3770K @ 4.50ghz
16gb DDR3
Creative SB0730 X-Fi Xtreme Gamer
Sapphire Dua-X R 280 Radeon: DVI-I-->VGA adapter
Ultimarc Video Amplifier
27" Makvision Tri-Mode Monitor
Foxhole
  • Last login:May 09, 2025, 05:02:07 pm
Re: Unable to pull a log file
« Reply #1 on: February 12, 2020, 04:59:06 pm »
Sounds like a permission issue (?)
Are you on Win10? Try running it from a different drive if possible or a folder that doesn't need permissions.
tjbaker6
  • Last login:March 31, 2020, 01:34:54 pm
« Reply #2 on: March 16, 2020, 11:22:13 pm »
Same issue here.   I have tried to place the log file in several directories with the same zero result.   It is as if mame64, while writing to its own sub cmd box/shell window, is not using stdout or stderr?   Beyond that, its over my head.
tjbaker6
« Reply #3 on: March 18, 2020, 11:33:30 am »
I loaded the standard (non-groovy) MAME64 on my machine and commands work fine with redirected output.  non-groovy mame does not open a child window and as a result, all output is captured when redirected.  the groovy version doesn't work.. can't get any output to redirect.  Is there something that can be changed/set in groovy mame so that output redirect works?
