Author Topic: HyperSpin Startup Script Error  (Read 1643 times)
dbeste
  • Last login:February 05, 2020, 05:17:03 pm
« on: February 04, 2020, 12:14:55 pm »
Hello,
I was hoping someone could help with a HyperSpin error after adding the HyperSpin Startup script. I downloaded the .exe and ran it first to generate the .ini.  I then added it to the Startup section in HyperHQ.  I launched HyperSpin and it gave the attached error.  No changes to the .ini file.  I did notice that the value being displayed is the value of the %TEMP% environment variable.  I changed the env variable to a value of C:\Temp, as shown in the message, and still get the error.  If I go into HyperHQ and remove the script I no longer receive the error. Also if I launch the script outside of HyperSpin I do not get the error. That’s whether I leave the .ini file as is or simply have it launch LEDBlinky. Any thoughts would be much appreciated.
Thanks,
Darren
« Last Edit: February 05, 2020, 05:17:03 pm by dbeste »
