Author Topic: Can I actually use an Aimtrak with HOTD2 on Demul/Naomi emulator?  (Read 2893 times)
SpatzST
  • Last login:April 18, 2021, 05:29:46 pm
edit: it seems the solution to my problem was from using "DemulShooter"... now to figure out how to get two guns working properly. :)
« Last Edit: January 28, 2020, 09:57:47 am by SpatzST »
SaputraJ
  • Last login:July 06, 2023, 12:47:41 am
Re: Can I actually use an Aimtrak with HOTD2 on Demul/Naomi emulator?
« Reply #1 on: February 25, 2020, 07:55:06 pm »
Hi, did you get both Aimtrak guns working property using Demulshooter?
Kierdo
  • Last login:October 27, 2023, 01:40:42 am
« Reply #2 on: April 05, 2020, 09:16:45 am »
You can use both aimtraks with Demul games.
I have them working without any problem. If you follow step by step the Demulshooter wiki and use the correct Demul version (detailed in demulshooter wiki) they may work.
In my case, followed step by step the instructions and are working great!
