Author Topic: Rowe CD 100F Julebox Volume Spikes when song start  (Read 5837 times)
retromusic
  • Last login:February 09, 2020, 02:51:45 pm
« on: January 18, 2020, 08:09:28 pm »
When the first song starts is louder than the normal volume is set to and it then fades to the proper volume after a few seconds.
I have read another person had the same experience and tried to follow the notes.  The service manuals which I have for the CD100F talk about Mech Control 61086201 P6 pins 7 (Mute) and 9 (AMP Ref).  The Jukebox has a 61048101 installed which does not have a P6 connector.  Can someone provide technical assistance with my issue?
Thank you.
lilshawn
  • Last login:May 25, 2026, 04:26:29 pm
Re: Rowe CD 100F Julebox Volume Spikes when song start
« Reply #1 on: January 19, 2020, 12:25:40 am »
in the middle of the amp between the EQ's is a plug and to the right of that is a 2 switch dip switch.
one switches from mono to stereo...
the other enables or disables AVC.  (automatic volume control)
flick that switch down to disable it.
retromusic
« Reply #2 on: January 19, 2020, 01:20:29 pm »
My Amp is a 61024901 and it does have a dip switch located in the opening.  I toggled it downward and powered the CD100F back on but it has the same issue.
Ken Layton
  • Guru
  • Technician
« Reply #3 on: January 19, 2020, 10:24:34 pm »
Has the amplifier been re-capped yet?
retromusic
« Reply #4 on: January 26, 2020, 09:46:18 am »
No I have not re-caped the amplifier.
