Author Topic: Can I use a Happ ball in my Suzo/Ultimarc track ball housing?  (Read 1591 times)
wakerlet
  • Last login:September 25, 2007, 11:37:53 am
  • 1-2-3-4..thats the combination on my luggage
« on: February 16, 2004, 07:50:43 am »
Hello,
I just bought a 2 1/4" trackball from Ultimarc and it only comes in two colors, red or white.  The question is, can I put a black happ ball in the trackball housing?  I think the control panel would look super slick with a black ball.
Anyone tried this or knows if it will work?
Thanks,
Todd
namzep
  • Last login:October 02, 2009, 01:13:40 pm
  • Twilight Zone: the Game
    • Pezchasers - Home of Twilight Zone: the Arcade Game
Re:Can I use a Happ ball in my Suzo/Ultimarc track ball housing?
« Reply #1 on: February 16, 2004, 08:25:46 am »
As long as you got the 2-1/4" replacement ball from Happs there would be no problem.  Any companies ball that is the right size should fit any other companies housing.
Tiger-Heli
    • Tiger-Heli
« Reply #2 on: February 16, 2004, 08:32:54 am »
Hello,
Thanks,
Todd
The 2-1/4-inch trackballs will also work with billiard balls, so you could use an 8-ball, if you would like that effect.
wakerlet
« Reply #3 on: February 16, 2004, 09:10:31 am »
Thanks.
So let me get this straight.  The Happ ball, in essence,  is just a pool ball?  Same weight, etc?
-Todd
Tiger-Heli
    • Tiger-Heli
« Reply #4 on: February 16, 2004, 09:15:49 am »
Thanks.
-Todd
That's not what I said.  I said it would work with a pool ball and others have done it.  (Not sure about the weight, although I'm pretty sure there's more difference between the translucent and solid Happ balls than the solid Happ and pool balls, FWIW.
Hopefully someone who's tried it can chime in.
