Author Topic: Mega touch Force 2011 black screen  (Read 4766 times)
Retrogamer78
  • Last login:August 16, 2020, 03:42:37 pm
« on: November 18, 2019, 10:16:52 am »
Hey guys. I’m looking at a Megatouch unit for a buddy of mine. During boot up the screen flashes on for just a second but then goes back to dark. The system boots ok but the screen is so dark you can just barely see the images with a flashlight up close. So you think this is a capacitor or power supply problem? Or maybe just a bad monitor?? I’m at a loss here.
mahkeymike
  • Last login:June 26, 2026, 09:42:19 am
Re: Mega touch Force 2011 black screen
« Reply #1 on: November 18, 2019, 11:12:59 am »
Bad CCFL's in the lcd panel, or bad monitor power inverter. Either way, you will need a new monitor.
lilshawn
  • Moderator
  • Last login:July 01, 2026, 04:44:09 pm
« Reply #2 on: November 18, 2019, 12:51:48 pm »
contact the dudes over at lcdparts.net with your model number of your monitor and the part make/model of the back-light invertor. they should be able to get something to replace it with. they are a little pricey, but they have always had a part that was 100% plug and play compatible.
Retrogamer78
« Reply #3 on: November 27, 2019, 08:03:17 pm »
 :applaud: Thanks a ton! I got it up and running. Really appreciate the input.
