Author Topic: Can't change volume or anything with Ipac 2 in Hypespin :(  (Read 1326 times)
equlizer
  • Last login:November 17, 2019, 02:56:48 am
  • All your base are belong to us
« on: November 12, 2019, 10:03:32 pm »
I cannot change volume or use any of the shift keys in hyperspin.  BUT......If I exit right out of hyerspin and start explorer.exe then go back into hyperspin i can change volume and use the other hotkeys.
Anyone have an answer? :(
Using windows 7 and i believe its shelled.  I had a friend set it up for me years ago so im not sure.
« Last Edit: November 12, 2019, 11:38:36 pm by equlizer »
keilmillerjr
  • Web Developer.
Re: Can't change volume or anything with Ipac 2 in Hypespin :(
« Reply #1 on: November 13, 2019, 02:40:10 pm »
Perhaps you need explorer for certain functions like volume control. Map a shifted sequence to a regular character key and see if it works inside notepad and without explorer running.
equlizer
« Reply #2 on: November 13, 2019, 07:50:11 pm »
Tried that.  It works in notepad.  Isn't explorer.exe supposed to be running?
I sort of got it working by running explorer.exe in the hyperspin setup and hide taskbar but now when i reboot and it goes into hyperspin, i can't access hyperspin till i hit esc on keyboard.
Why is it so hard to control the volume in hyperspin? :(
