Author Topic: Ultimate mk3 controls not working  (Read 6389 times)
tealsnk
  • Last login:November 22, 2020, 03:21:47 pm
« on: October 29, 2019, 06:24:56 pm »
I recently purchased a ultimate mk3 pcb board, I installed into a mk4 cabinet. It boots up fine, however none of the joysticks and buttons work at all. I thought that that the kick harness for mk4 and umk3 would be the same and would be plug n play. Any ideas as to why the controls don't work at all. Thanks
Sent from my SM-G955U using Tapatalk
Titchgamer
Re: Ultimate mk3 controls not working
« Reply #1 on: October 30, 2019, 02:45:32 am »
If none of your controls are working at all the first thing I would check is the continuity of your ground loop for them.
After that its cracking out the drawings and doing it wire by wire....
tealsnk
« Reply #2 on: October 30, 2019, 05:52:08 am »
Ok, I may give that a try. Weird part is that mk4 ran great before. After not having any luck with the umk3 board controls I put the mk4 board back in and it plays perfectly. Maybe umk3 board issue?
Titchgamer
« Reply #3 on: October 30, 2019, 07:13:39 am »
Possibly a board issue or its wired totally different.
Are they both Jamma boards?
tealsnk
« Reply #4 on: October 30, 2019, 11:09:08 am »
Yes, both are jamma boards. One thing I did notice is that the pin connectors on the umk3 board are very worn out where the jamma harness slides on. The silver on there is almost gone on quite a few. Not sure if that would cause the controls not to work. My understanding is thay mk3, umk3 and mk4 have all the exact same harnesses.
Titchgamer
« Reply #5 on: October 30, 2019, 11:34:50 am »
Well each control has its own pin so to have all of them completely worn out woukd be unusual.
Is the ground connector badly worn away?
If so that will be your problem!
tealsnk
« Reply #6 on: October 30, 2019, 11:54:13 am »
Here's a picture of the worn out parts on the board, I would say the ones on the far right look more worn out to me. The other side looks the same too.
Titchgamer
« Reply #7 on: October 30, 2019, 11:58:21 am »
The 2 on the bottom are your grounds (same on the other side) and look badly worn.
tealsnk
« Reply #8 on: October 30, 2019, 11:59:52 am »
Yeah, you're right. I checked the jamma harness pin out and they are indeed grounds. That definitely explains it then.
Titchgamer
« Reply #9 on: October 30, 2019, 12:00:32 pm »
The 2 pins furthest away both sides are grounds also.
tealsnk
« Reply #10 on: October 30, 2019, 12:10:20 pm »
The ones on the left side are slightly worn out, not as bad as the other side. Looks like I'll be returning this umk3 pcb then.
Titchgamer
« Reply #11 on: October 30, 2019, 12:20:54 pm »
If you just brought it I would defo return it.
tealsnk
« Reply #12 on: October 30, 2019, 12:52:24 pm »
I did just buy it, going to return it for a refund. Thanks for all the advice, much appreciated.
  • Last login:Today at 11:33:31 am
« Reply #13 on: October 30, 2019, 12:54:53 pm »
