Hey guys,
I'm running Groovymame 0.214 on a Sanyo 20EZ in an original DK cabinet. Because the colors are inverted, I'm using a Nintendo Edge to Jamma adapter that amplifies sound and inverts colors.
I'm trying to make my mame games look as good as the original PCB and it definitely does look great in terms of colors.
To switch from original PCB to Groovymame, I do the following:
- Plug in Nintendo Edge to Jamma Inverter Board
- Plug into JPAC
- Change Brightness Pot from Min to Max
- Connect sound cable
What's not looking right is horizontal lines appear squished somehow (see photos). The "I" and "T" in CREDIT look too thin and have a dot on top, very strange.
I'm running super resolutions. DK3 has a resolution of 256x224 which I'm running at 2560x224 through switchres/groovy.
Things I've tried:
- Try different resolutions (240p,256p...) It looks somehow better in 480i but I definitely don't want to run it interlaced.
- Try different Jamma adapter. I have one of these old parrallel port adapters. Result: Screen doesn't look bright enough but line spacing seems a lot better.
Do you guys have any ideas what else to try. My goal is to have groovymame look as good as original hardware. Right now unfortunately it's not quite there yet..
Original PCB:
JPAC:
OLD JAMMA ADAPTER:
The line squishing is a lot more apparent in person than on the photo
