Author Topic: ultimarc u-trak and mini-pac wiring problems  (Read 2081 times)
markiej
  • Last login:November 01, 2020, 02:15:56 pm
« on: September 26, 2019, 04:39:24 pm »
hey there - got everything else wired up and working, except the trackball (which now doesn't work).  Anyone go down this road before?
  • Last login:Today at 03:44:56 am
Re: ultimarc u-trak and mini-pac wiring problems
« Reply #1 on: September 26, 2019, 05:10:30 pm »
Check your connections.
- The Mini-Pac optical harness has three optical input connectors.
- Make sure you are on the trackball connectors and that they are facing the right way. (red 5v to red 5v, black GND to black GND)
- The trackball and spinner connectors have a different pin order.   :banghead:
markiej
« Reply #2 on: September 26, 2019, 10:09:45 pm »
Thanks - I got it working!  good tip - of course none of the colors u-trac colors lined up, I had to poke around a bit and trace some lines.
Except now none of group J4 is working.  Not one.  And when I connect the devices to other groups - it works fine.
Edit: I fixed it by going in and manually setting the keys - they were soft-disabled.  Must have disabled them in a fugue state?
« Last Edit: September 26, 2019, 10:25:02 pm by markiej »
