Author Topic: Anyone know of a source for new nintendo audio transformers  (Read 1362 times)
GMZombie
  • Last login:March 22, 2022, 10:11:23 am
  • I am a living Legend who fixes stuff... mostly
« on: August 29, 2019, 09:22:21 am »
Just as the sub says im looking to find a new audio transformer for mt sanyo ez20 monitor as mine i think is bad. When i check the ohms on each side and the 260ohm side is reading 40 ohms and the 8 ohm side is reading 1.4ohms. I have recapped my aidio board and replaced my transistors on the board along with theudio smp on the pcb. Still no audio
langlem
  • Last login:May 27, 2025, 04:58:19 pm
Re: Anyone know of a source for new nintendo audio transformers
« Reply #1 on: August 29, 2019, 09:43:38 pm »
I used this... worked fine.  Probably overkill as it really is not the intended purpose...but I had one lying around. (I just used the audio section)
https://www.mikesarcade.com/cgi-bin/store.pl?sku=NININVAMP
You could also just use one of those cheap amazon/ebay amps.  Run the audio out directly from your game pcb to the audio in on the amp, tap into 12v to power the board, connect cabinet speakers to the amp and you are gold.
I recently did this on a DK cab to eliminate the speaker hum.
Worked like a charm.
https://www.amazon.com/DROK-TDA7297-15W-Amplifier-Component/dp/B00C4MT274/ref=pd_cp_23_1?pd_rd_w=wOVgB&pf_rd_p=ef4dc990-a9ca-4945-ae0b-f8d549198ed6&pf_rd_r=8ZJGNY3D0GQK8AMR46Z5&pd_rd_r=d307e9d6-1657-4f4c-8e07-971729529817&pd_rd_wg=wc3YB&pd_rd_i=B00C4MT274&psc=1&refRID=8ZJGNY3D0GQK8AMR46Z5
This would help as well...
