Author Topic: Happ trackball question about PCB's  (Read 2299 times)
boslaw2
  • Last login:March 07, 2021, 08:24:04 pm
« on: August 15, 2019, 11:21:56 am »
I have an old Happ trackball with green PCB's. The trackball no longer registers horizontal movement, so I suspect one of the PCB's doesn't work. Can I replace the old green PCB's with the newer red PCB's? The trackball is the kind with the PS2/USB interface.
behrmr
  • Last login:April 23, 2021, 09:17:13 am
Re: Happ trackball question about PCB's
« Reply #1 on: August 15, 2019, 02:42:03 pm »
You can but you will need to swap the dir and clk wires in your harness.  I believe these are the two outside wires in the 4 pin molex connector
boslaw2
« Reply #2 on: August 15, 2019, 02:50:29 pm »
I don't have the trackball in front of me, but are you talking about a molex from the trackball to the PCB? From PCB to computer is connected by USB.
behrmr
« Reply #3 on: August 15, 2019, 11:26:47 pm »
The connector on the optic boards on the trackball.
