Author Topic: Tall(er) Cocktail Cabinet  (Read 4688 times)
BlueGhost
  • Last login:March 12, 2026, 03:58:58 pm
« on: August 09, 2019, 04:28:27 pm »
I'm finally starting equipping the gameroom in the new house.
I'm going to build a cocktail cabinet.  The gameroom will also have a pool table.  I think the standard cocktail table height is a little low and asking for someone to get hit in the face with the butt of a pool cue.
Has anyone here built a taller cocktail style cabinet?  I'm thinking kitchen counter height rather than bar height.  I think it would interfere with shooting pool less at counter height.
Sent from my LM-V350 using Tapatalk
« Last Edit: August 09, 2019, 04:34:49 pm by BlueGhost »
JDFan
« Last Edit: August 09, 2019, 04:44:14 pm by JDFan »
lilshawn
  • Last login:June 16, 2026, 07:23:28 pm
Re: Tall(er) Cocktail Cabinet
« Reply #2 on: August 09, 2019, 05:23:27 pm »
I modded a pokertek machine into a multi in 1 machine. it's a full stool table kind of height...you can easily play standing up.
BlueGhost
« Reply #3 on: August 09, 2019, 05:29:48 pm »
I think the barrel would protrude out in the room to far by the time I added a round glass top.
The moded video porker might work.
I may just build a midway style cocktail and add 10 inches or so to the height.
The benefits of the midway style is glass, underlays and control paneles are all available for it.
  • Last login:May 19, 2026, 11:21:47 am
« Reply #4 on: August 09, 2019, 07:18:04 pm »
Stay away from the barrels and google “cabertail”
« Reply #5 on: August 09, 2019, 08:18:01 pm »
I assume the Atari Football arcade game is a bit too big. That was a big fat cabinet, but the height is right.
BlueGhost
« Reply #6 on: August 09, 2019, 09:52:31 pm »
I think the Atari football style would be a little big.
One thing I thought about is getting a restaurant style table base and build a midway style top for it.  It would be similar to the poker machine above.
BlueGhost
« Reply #7 on: August 09, 2019, 09:56:44 pm »
Cabertail could work.  Kind of like a tall cocktail.
« Reply #8 on: August 09, 2019, 09:57:29 pm »
Never seen a custom build- you’d be a trailblazer!
  • Last login:Yesterday at 12:33:17 am
« Reply #9 on: August 09, 2019, 11:05:12 pm »
I'd like to see that, or maybe a slimmed-down modernized red tent.
  • Last login:Yesterday at 03:17:50 pm
« Reply #10 on: August 09, 2019, 11:30:51 pm »
Sounds a bit like mgb's VertiGo.
  • Bitches love Centipede
« Reply #11 on: August 09, 2019, 11:39:51 pm »
Shame it wasn't completed...
%Bartop
BlueGhost
« Reply #12 on: August 10, 2019, 12:18:20 am »
That's the basic concept.  I thought I had seen something like it on here before.
I found this while looking for taller cocktail cabinets.
https://imgur.com/gallery/eVJgF
Its tall, but thinner, less boxy than a traditional cocktail cabinet.
negative1
  • Last login:June 18, 2026, 08:16:54 pm
« Reply #13 on: August 10, 2019, 01:41:59 pm »
watch out for porky pig:
later
-1
Mr. Peabody
  • Last login:June 07, 2026, 04:15:16 am
« Reply #14 on: August 10, 2019, 07:16:42 pm »
That is beau-tiful. Could modify the base and adjust height at whim.
« Reply #15 on: August 11, 2019, 12:38:04 am »
A taller standing cocktail would be pretty neat. Haven’t seen a completed BYO cab of those completed. Looking forward to what you come up with.
« Reply #16 on: August 11, 2019, 03:32:01 am »
You've really got to worry about it tipping over though.  The bottom would have to be weighted and I'd still be a little nervous letting kids get around it, ect.
lilshawn
« Reply #17 on: August 11, 2019, 06:51:31 pm »
the pokertek machine base is solid cast, weighing in at what i'd guess to be about 150lbs. the center is hollow metal tube (I assume cast aluminum) and the top portion is sheet metal "frame" with a fiberglass outer shell. the entire machine weighs in at a bit over 200lbs and 3/4 of the weight is between 0 and 3 inches off the ground...so it's super stable.
even with the thinner "traditional" cocktail design posted earlier, i think if you threw in a couple 50 lb bags of play sand in the bottom of the cabinet...you'd never have to worry about it being tippy at all.
