Author Topic: WG K4900 ghosting/double image after recapping, Millipede upright  (Read 1725 times)
mattym
  • Last login:August 02, 2019, 05:15:29 pm
Hi, looking for some help. I just finished a recapping of a K4900 to address vertical collapse. The collapse is gone after recapping, but I've now got a ghosting/image duplicating issue along with a flicker issue. Anyone have any ideas? Areas to check? I played w/ the various pots a little bit but nothing helped.
This is in a Millipede upright, so vertically oriented monitor. Millipede composite sync going to K4900 NEG H SYNC post (although same issue swapping to the K4900 neg v sync). You can clearly see in the attached photo all the overlaying/duplicating of the image parts.
grantspain
Re: WG K4900 ghosting/double image after recapping, Millipede upright
« Reply #1 on: August 03, 2019, 06:04:25 am »
it looks like vertical hold pot needs more adjusting
