Author Topic: Screen blank after latest edid loading  (Read 2408 times)
wichitakid71
  • Last login:July 29, 2025, 01:41:01 pm
« on: July 04, 2019, 06:27:12 pm »
I have been messing with my monitor for a few weeks now trying to find the best combination of settings and modes to run groovy Mame, retroarch and my desktop.  My monitor is a Makvision 3125 tri-mode, so I have tried a number of different presets and settings.  My last attempt was to emulate a generic tri-sync monitor, but for whatever reason it was only entering settings for a dual sync monitor. I tried to undo this EDID setting and that’s when things went to pot.  Currently now the only thing I see with my Radeon card or my Intel onboard graphics is the boot screen (I flashed it to 15khz/31khz and it still appears to work).  Once the computer is done booting up, my screens go black. I am using a LCD monitor and my Makvision to test this out.  I know I must have set the resolution to something that my LCD can’t display, and for whatever reason my tri-mode is having trouble as well. I want to just restore this thing to prior settings and start all over again, but I can’t even see a window screen to get that done.
EDIT:  Card is a Radeon HD 8490, CPU Intel i5 4th gen, 8 GB ram.
I would appreciate any help, as this is really stopped my build in its tracks.  Thanks in advance.
« Last Edit: July 04, 2019, 07:02:46 pm by wichitakid71 »
buttersoft
  • Last login:Yesterday at 07:14:32 pm
  • Is running at 15kHz
Re: Screen blank after latest edid loading
« Reply #1 on: July 04, 2019, 09:55:16 pm »
The easiest thing to do would be reinstall windows.
Do you have a multimeter that can measure frequency/Hz? Put it on the h-sync or c-sync line and see what it reads.
wichitakid71
« Reply #2 on: July 04, 2019, 10:32:22 pm »
No on the multi meter. The OSD on the LCD says that my horizontal frequency is 48.4 KHz and the vertical frequency is 60.
wichitakid71
« Reply #3 on: July 04, 2019, 10:38:31 pm »
On the Makvision, after it boots up and I see the Dell logo (at what appears to be high tea), I hear the monitor click and the screen blinks out as if it is switching resolutions. It then remains black after that.
wichitakid71
« Reply #4 on: July 05, 2019, 01:24:16 pm »
Anticipating that I get my windows back to a workable resolution, what is the correct EDID/preset combo for my Makvision?  It has a switch that is supposed to control 15/24 kHz and 31 kHz.  Does that mean I have to choose one or the other?  It also seemed to work for awhile when I told Vmmaker that it was a std res only - arcade 15.7.  I’d like to find the optimal settings and leave it there.
Thanks for the guidance.
