Author Topic: Joystick question  (Read 1405 times)
woosdom
  • Last login:June 13, 2025, 06:14:45 pm
Joystick question
« on: July 01, 2019, 01:13:26 pm »
I ordered a Zippy joystick but I received an LED Joystick instead. The model is LED-JS-248-BLUE. I will be returning it for the Zippy.
Has anyone used this joystick before?  I would like to check out how the led looks. What is an easy way to power it up while I still have it?
  • Last login:March 31, 2026, 11:05:22 pm
Re: Joystick question
« Reply #1 on: July 01, 2019, 01:27:44 pm »
If you received a more expensive joystick by mistake, I'd keep the more expensive joystick....
 :dunno
  • Last login:Today at 05:19:48 am
« Reply #2 on: July 01, 2019, 05:20:05 pm »
Assuming the underside looks like this . . .
. . . hook ground and 12v to the upper left pins.
5v should work if you don't have a 12v source, but the LEDs will probably be a bit dimmer.
Not sure what kind of jumpers/adapters/power sources you have available.   :dunno
An I-Pac (5v and ground Dupont pins) and two F-F Dupont jumpers would probably be the easiest way.   ;D
