Author Topic: Connecting AMI R82 to AMI wrd200 wallboc  (Read 2818 times)
Pointman
  • Last login:June 30, 2019, 04:56:04 pm
« on: June 30, 2019, 04:56:04 pm »
I have a ROWE AMI R82 julebox I would like to know what I need to connect  my WRD 200 wallbox jukebox. On data plate it requires 30 v, the one on the juke now is 70v off terminal strip. On jukebox it has 8 terminals for connection. The wrd 200 has the same. Iwould really appreciate your advise.
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
Re: Connecting AMI R82 to AMI wrd200 wallboc
« Reply #1 on: July 05, 2019, 06:28:41 am »
Hello Pointman,
Sorry you did not leave a name.
You need a wallbox transformer that gives an output of 30 volts AC.
The 70 volt you refer too on your jukebox is the two 70 volt line connections that is used for connecting speakers on very long runs, this uses 70 volt line transformers at set wattages fir use in toilet and stairwell speakers.
Regards
Alan Hood
ami-man
UK
