Author Topic: rotary encoder Ipac2  (Read 3391 times)
quakebo
  • Last login:January 30, 2023, 02:13:01 pm
« on: June 16, 2019, 07:16:39 am »
Will a rotary encoder work with an Ipac 2.
  • Last login:Today at 12:07:32 am
Re: rotary encoder Ipac2
« Reply #1 on: June 16, 2019, 05:08:57 pm »
To be clear, you're talking about one of these, right?
The one I ordered from Amazon works well with StefanBurger's Illuminated Spinner firmware on an Arduino.   ;D
It should work fine with the optical input pins on the IPac 2 (2015 or newer) as long as you don't hook the wires up wrong.
- IIRC accidently connecting 5v to a data line will damage the encoder.
On the other hand, n3wt0n mentioned here that the ones he ordered on e-bay didn't work.   :dunno
quakebo
« Last Edit: June 17, 2019, 01:37:48 pm by quakebo »
  • Last login:Yesterday at 12:57:55 pm
« Reply #3 on: June 17, 2019, 01:04:03 pm »
Your link is foobared, we can't reach the page.
quakebo
« Reply #4 on: June 17, 2019, 01:39:00 pm »
if you right click the link and open in new tab it works.
meyer980
  • Last login:January 26, 2026, 08:20:18 pm
  • Building fun things for fun
    • sergiostuff.com/2020/04/15/felix-son-arcade-game/
    • Sergio Stuff
« Reply #5 on: June 17, 2019, 02:51:56 pm »
I've used the KY-040 rotary encoder with the mini-pac which is quite similar to the one you linked. So, I would think it should work.
« Reply #6 on: June 17, 2019, 07:24:15 pm »
What size is your project and how are you planning on using this encoder?
- EC11's are low resolution (24 transitions per rotation IIRC) so they are really not a good choice for an arcade spinner.
- One application where an EC11 might make sense is in a micro-cab where there isn't room for a normal rotary encoder.
If you're looking for a full-size spinner with a small/shallow footprint, check out GGG's TurboTwist Sci-Winder.
quakebo
« Reply #7 on: June 17, 2019, 07:36:02 pm »
I will be using them on a button box for sim racing.
« Reply #8 on: June 17, 2019, 08:00:24 pm »
EC11's should work fine for that application.
How many axes will you need?
If you need more than 2 (X-axis and Y-axis) you'll probably need another optical (mouse) encoder.
quakebo
« Reply #9 on: June 18, 2019, 07:00:11 am »
My plan was to use 4 EC11S.
« Reply #10 on: June 18, 2019, 08:16:26 am »
OK.
First two EC11's on X-axis and Y-axis via the IPac's trackball pins -- no problem.   ;D
You'll need another optical (mouse) encoder for the other two axes because the IPac's normal button inputs (apply ground to the input ==> IPac outputs a keystroke) won't translate the EC11's output quadrature waveforms into mouse axis movements.
An Ultimarc U-HID Nano or an Arduino Pro Micro with a slightly-modified (i.e. not using X- or Y-axis) mouse sketch/firmware should be able to translate EC11's three and four into mouse axis movements for your racing sim.   :cheers:
Depending on how inputs are handled by the sim, Z-axis (scroll wheel) can cause the 4:1 problem in Windows.
- Instead of outputting 1 step per transition, Windows outputs 4 steps per Z-axis (scroll wheel) transition.
If possible, use X-Ro (X-Rotation) and Y-Ro (Y-Rotation) axes for three and four.
quakebo
« Reply #11 on: June 18, 2019, 12:55:39 pm »
Thanks for that.  now I already have a Arduino Pro Micro I was going to use but wanted to know if a Ipac2 would work.
