Author Topic: Multi Games xxxx in one/Pandora's box resolution.  (Read 5045 times)
CHRIS-F
  • Last login:October 17, 2025, 12:26:28 pm
  • I always have screws left over after repairs :-)
« on: June 01, 2019, 04:28:40 pm »
Just a quick question on those Pandoras box or xxx games in one, do they just plug into the jamma connector and work on the crt like any game board, once you set the h/v width/height amplitude do all the games then just get stretched/shrunk to fit the screen? are they any good? good/bad points?
I purchased an arcade vga & j-pac years back, I was going to run mame, but never got round to it. In all honesty I think a multi games thingy would be a better option, I only want to play a few games ghosts n goblins/wonderboy etc and I want to buy them on real pcb's also, but I guess it's easier if you can just fire it up and choose the game.
Cheers,
Chris.
Re: Multi Games xxxx in one/Pandora's box resolution.
« Reply #1 on: June 01, 2019, 10:23:35 pm »
My review:
They are a solid ok, but what you think is going to depend on your expectations, your level of commitment to authenticity, and the types of games you like. What they definitely are is easy and inexpensive.
CHRIS-F
« Reply #2 on: June 06, 2019, 06:55:29 am »
My review:
Thanks, I personally like to run PCB's I just have a few favourites and don't mind changing them out once in a while, but might be a good idea to get some kind of box for the kids, should be relatively easy to just swap the jamma harness over from one to the other :-)
CHRIS-F
« Reply #3 on: June 06, 2019, 07:03:47 am »
Apologies if it breaks any forum rules asking about such devices, but if its allowed can anyone recommend a good xxx in one/Pandora etc, that just plugs into the jamma harness runs from the arcade psu and works with the CRT?
Ideally mostly just horizontal platform games for the kids, Bubble Bobble/Wonder Boy/Ghost's n' Goblins etc, I'll most likely buy them on real pcb,s also but you know what kids are like they want to change games all the time.
Thanks again
Chris.
  • Last login:Today at 10:11:47 am
« Reply #4 on: June 06, 2019, 07:04:02 am »
I have one that came with a Candy Cab I bought. It works great to keep the kids that come to my arcade occupied with their shorter attention spans. They don't care how accurate the emulation is.
FrizzleFried
    • Idaho Garagecade
« Reply #5 on: June 06, 2019, 09:09:57 am »
While the cost is a bit more,  the ARpiCADE is a worthy consideration.
I'm not a big fan of the Pandora's Box units... though they ARE better than the xx-in-1 garbage that is out there.
« Last Edit: June 06, 2019, 09:11:53 am by FrizzleFried »
CHRIS-F
« Reply #6 on: June 06, 2019, 09:47:52 am »
Thanks for that, didn't know about ARPICADE, it looks really good, the price is a bit steep though, I want to spend a bit getting my cabinet sorted first, but that looks like a good idea in the near future :-)
Just curious though what is it that people don't like about those Pandora's?
I actually bought a J-pac and arcade-vga a few years back I spent ages tweaking the Mamewah front end on an an older pc I had running windows 7, but I had so many issues, I kept loosing sync couldn't get the resolution to work properly, my psu failed the monitor had interference and eventually the pc died so I ripped it out and bought a game pcb, turns out most of my issues wer actually my monitoir/psu/and a faulty j-pac which Andy kindly replaced, but I just didn't have the heart/patience/time to buy a new pc and set it all up again, does anyone still use front end/jpac/vga setup?
FrizzleFried
    • Idaho Garagecade
« Reply #7 on: June 06, 2019, 10:11:45 am »
Lack of individual game options.  Screen tearing.  Spotty emulation (game dependent).  Limited menu.  The typical stuff you get with an all-in-one Chinese MAME multigame.
  • Last login:May 15, 2026, 05:08:29 pm
« Reply #8 on: June 06, 2019, 11:44:18 am »
Anyone played the King of Air / Air Attack boards?  I'm considering getting one for my 60 in 1 bartop.  Might be fun to change it up a little.
FrizzleFried
    • Idaho Garagecade
« Reply #9 on: June 07, 2019, 08:31:39 am »
You can often times find the King of Air as a separate "image" for PB4.   It's OK... not many games to the list.... again... you get what you pay for and these are pretty cheap.  If you're OK with a 60-in-1,  you'll likely be fine with the King of Air.
Tarma
  • Last login:August 18, 2025, 01:20:58 pm
« Reply #10 on: June 07, 2019, 10:34:18 am »
"can anyone recommend a good xxx in one/Pandora"
I can't say directly but what you want to look for with PB units is the processor, not how big the game list is (some of the newer units let you add your own games anyhow). Currently the best model has:
CPU Quad-core Cortex-A7 1.2GHz
GPU Mali400MP2@600MHz
If you've only seen the older models (PB4 and earlier) these new ones run much better / faster. Most of the clones of the PB are still using the older hardware however so even though they have 2000+ games on them many of the games barely run.
tommyinajar
  • Last login:November 15, 2023, 12:23:20 pm
  • My other cab is a Cube Quest
« Reply #11 on: August 11, 2019, 08:37:50 pm »
Is there anyplace that has info on the different versions or is 9D-SF the latest and greatest -
compared to the Ebay ones?
For that price might as well try it- This uses a standard Jamma or?
EDIT-
I'll just post a new thread instead of hijackn' this one...lol
« Last Edit: August 12, 2019, 03:34:23 pm by tommyinajar »
