Author Topic: VMMaker custom resolutions while keeping original ones?  (Read 4398 times)
Stremon
  • Last login:November 20, 2019, 12:05:21 am
« on: May 26, 2019, 02:21:11 am »
So I've been using the last version of CTR Emudriver and VMMaker, and it's working awesome so far.
But there is one thing I want to do but don't know how.
I have a good 4:3 PC CRT monitor that can display pretty much any resolution from 640x480 @ 60Hz and up.
When I use VMMaker to create the necessary custom resolutions (with 3, I am losing all the monitor original resolutions, and beside the custom resolutions, only get 16/9 resolutions somehow (720p, 1080p...).
Since I want to use my PC for other things than GM, is there a way to keep my monitor EDID resolutions when adding the custom one?
Thanks ;)
Calamity
  • Moderator
  • Last login:October 06, 2026, 11:20:38 am
  • Quote me with care
Re: VMMaker custom resolutions while keeping original ones?
« Reply #1 on: May 26, 2019, 03:15:33 pm »
If you don't enable EDID emulation you shouldn't loose your native modes. What card, and version of Emudriver?
Steps to create a log:
Stremon
« Reply #2 on: May 26, 2019, 05:53:51 pm »
You mean I can use the custom video modes without the EDID emulation?
I use a Radeon HD 5770 with Emudriver 2.0 beta 15 (crimson 16.2.1).
Calamity
  • Moderator
« Reply #3 on: May 26, 2019, 05:58:26 pm »
Sure. EDID emulation is just for monitors without an EDID.
Stremon
« Reply #4 on: May 26, 2019, 06:14:02 pm »
Oh I see! I didn't know that. thanks, I will try it :D
Works perfectly indeed! thank you ;D
« Last Edit: May 27, 2019, 08:01:25 am by Stremon »
Stremon
« Reply #5 on: May 26, 2019, 11:16:41 pm »
While I am here, do you know how to make retroarch work with those custom super resolution modes?
I tried pretty much every setting possible, but retroarch just doesn't want to change the resolution when loading a game  :'(
Calamity
  • Moderator
Stremon
« Reply #7 on: May 30, 2019, 01:24:58 pm »
 Thanks, i will try that :D
