Author Topic: Bliss-Box Gamer-Pro reaching consoles and more.  (Read 5875 times)
ulao
  • Last login:February 11, 2026, 04:59:59 pm
« on: May 08, 2019, 01:47:31 pm »
Hi all,  rolling out the new product Gamer-Pro and also dropping a note about console support and more. The Gamer-Pro is a single player version of the ever growing 4-play adapter. The device is %100 the same but designed to be more compact. In addition there are a few firmware options now available and more to come via the upcoming Bridge adapter.
Current firmware's are:
Switch
Xbox
Ps3
PC/Android/and most other OS's
Available here https://bliss-box.net/downloads/
These firmware allows you to just plug them in to the consoles and use as they were original hardware. The Gamer-Pro is based on usb 1.1 so there are limitations in what it can do. However, the new Bridge (not yet available) will allow a greater reach. It uses a light weight protocol (LLAPI) to communicate to Bliss-Box products. the protocol is open and can be used with other devices. It is currently used on the MiSTer for example. You can follow the Bridge and LLAPI  on the blog, https://bliss-box.net/blog/
You can contact us and get more info via the links below.
https://www.facebook.com/blissboxadapter/
https://twitter.com/blissboxadapter
