Author Topic: Diagram for assembly of WICO LEAF sticks?  (Read 1330 times)
GroovyTuesdaY
  • Last login:June 07, 2005, 03:22:18 am
  • "Follow the white rabbit! ....KNOCK KNOCK NEO...."
« on: February 12, 2004, 03:44:54 am »
Does anyone know where, either a website or some other resource, i can get a copy of a wico leaf joystick installation / assembly card?
I am wondering if i putting my back together right. Like a dumbass, i was in a hurry to take it apart so i could take the pieces to work and clean them up and now that i am getting ready to put it all back together, i am starting to question whether i am putting the pieces back in the right order.   So, if anyone knows where i can find some assembly instructions that would be AWESOME!   Like wise, if someone know FOR SURE, the correct order that the pieces should go back together i would be grateful as well.
thanks again,
groovY~
In the mighty words of the BEE GEES im-
"STAYIN' ALIVE, STAYIN' ALIVE!"
hehehe
paigeoliver
  • Awesome face!
Re:Diagram for assembly of WICO LEAF sticks?
« Reply #1 on: February 12, 2004, 05:49:19 am »
K.
The washer should be inside the plastic base, if it isn't there, then take apart the plastick base and get it in there. You should be able to shake it around in there until you put the stick back on the base.
Stick the handle in.
Then put the spring on the handle.
Put the actuator on the handle.
Put the E clip on the handle.
NoOne=NBA=
« Reply #2 on: February 12, 2004, 08:42:38 am »
Oscar posted some pics here awhile back.
