Author Topic: valvo vcc 91 chassis - unable to adjust horizontal size  (Read 1976 times)
perjmolsen
  • Last login:December 08, 2022, 04:09:06 am
  • I want to learn, and try.. I NEWER give up :)
    • My gameroom
« on: April 30, 2019, 05:29:44 am »
Hi
I have got an old German manufactured Arcade cabinet, model TV-IDEAL
In this cabinet there is an arcade monitor with an valvo vcc 91 chassis.
Documentation to the chassis can be found here ->
http://files.arcadeinfo.de/Monitore/Valvo%20Compact%20Chassis%20VCC%2091.pdf
The monitor is turned vertical.
My issue is that I am unable to find the adjustment pot that adjusts the normal with of the picture.
I have tried to turn the "L102" H-ampitude but it does not seem to change anything ( I have turned it 2-3 times both ways, nothing happens)
If i try to turn "P 301" H-Bildlage I can move the picture.
What can be the cause for the missing stretch of the picture?
I do now know when, or the chassis has got a cap kit replacement job.. The picture looks "OK" the agte of the game and so on, so A cap kit where not my first guess..
« Last Edit: April 30, 2019, 05:33:30 am by perjmolsen »
perjmolsen
    • My gameroom
Re: valvo vcc 91 chassis - unable to adjust horizontal size
« Reply #1 on: April 30, 2019, 05:38:23 am »
Hmm just noticted that there is a "L101" - H - linearität.
That adjustment pot mig be the one that adjust the horizontal size...
Why is it not on english  :D
princess prin prin
  • Last login:Today at 05:37:53 pm
  • intrinsically safe
« Reply #2 on: April 30, 2019, 08:46:55 am »
It's really only L102 but the core needs to be turned many times to make any change and in any case it will be a small change.
perjmolsen
    • My gameroom
« Reply #3 on: April 30, 2019, 08:58:51 am »
Hi
Ok thanks !  :cheers:
I where unsure what L102 did, because i could not see any changes on the screen, so i did not want to turn it to much.
perjmolsen
    • My gameroom
« Reply #4 on: May 02, 2019, 02:00:09 am »
Hi
I Have now turned L102   all the way down in the coil and it did the picture wider, but not all the way, still missing 1-2 cm
Can the reason be bad caps?
