Author Topic: Intermittent frame delay tearing  (Read 2328 times)
bjt42
  • Last login:February 03, 2022, 06:24:37 am
« on: April 24, 2019, 03:45:08 am »
My setup is working great with d3d9ex, portaudio etc so I had a play with frame delay to try to reduce lag further.
i5-3470, HD5450, super resolutions, GM 0.205. The test game was Shinobi.
50% of the time I launch the game, I can run up to frame delay 6 before I start getting slowdown and audio stutter (no tearing though).
The remaining 50% of the time, even at frame_delay 1 I get tearing about 1/3 down the screen.
The tear/no-tear state seems to persist within each instance of MAME.
Any ideas? I wondered if the 5450 is struggling to blit the 2560 wide mode, but that doesn't explain why sometimes it works up to frame_delay 6 without tearing?
bjt42
Re: Intermittent frame delay tearing
« Reply #1 on: April 25, 2019, 03:47:42 am »
Did some more testing, all works fine with a non-super resolution. So it must be that the 5450 is too weak.
Calamity
  • Moderator
  • Last login:September 10, 2026, 03:38:00 am
  • Quote me with care
« Reply #2 on: April 25, 2019, 04:41:57 am »
Some jitter affecting GPU performance is expected. Often, you avoid its effects by using the vsync_offset option.
The 5450 is weak but it should be able to render 2560x240p without performance issues. 2560x480i is a different story.
Steps to create a log:
