Author Topic: Cannot get vertical games to run in 240p. Switches to 496i  (Read 2536 times)
bodine1231
  • Last login:March 21, 2019, 10:50:11 pm
« on: March 17, 2019, 11:56:54 am »
Have all the latest builds on windows 10,ati 5450. I'm trying to set up a vertical only cabinet on my Astro City. Every game that I try switchres changes it to 1248x496i instead of 320x240p and makes everything look blurry. I'm sure theres an easy setting but I searched all over and cant find.
Calamity
  • Moderator
  • Last login:July 02, 2026, 04:35:40 am
  • Quote me with care
Re: Cannot get vertical games to run in 240p. Switches to 496i
« Reply #1 on: March 17, 2019, 12:00:45 pm »
You need to tell GM that your setup is vertical. You do that by means of the -orientation option. Use either -orientation rotate_r or -orientation rotate_l.
Steps to create a log:
bodine1231
« Reply #2 on: March 17, 2019, 12:07:05 pm »
When I launch mame its already rotated,the orientation is set to vertical in the .ini.
bodine1231
« Reply #3 on: March 17, 2019, 12:18:21 pm »
Ok tried something different. In 'settings' on VMMaker I changed monitor rotation from "vertical fixed" to "rotating to the right". Games are launching in 240p but they are squished now
(testing on PVM until i move to cab)
« Last Edit: March 17, 2019, 12:24:48 pm by bodine1231 »
bodine1231
« Reply #4 on: March 17, 2019, 12:26:49 pm »
Fixed it! I unchecked (desktop rotates too) in the VMMaker settings.
