Author Topic: Jukebox Washing machine???  (Read 3659 times)
NiN^_^NiN
« on: February 11, 2004, 05:09:49 am »
Ok this might sound wierd but could u use a old washing machine as a jukebox?
Cause its metal it would shake when its turned up wouldnt it?
I was thinking u could have a subwoofer in the front a monitor where the Lid is and buttons and knobs where the washing panel is.
Does this sound crazy? I think if u put lights on and plexi the top of it it would look good and be very different :)
But yeah im crazy :P
papaschtroumpf
  • Last login:July 23, 2013, 11:41:10 pm
  • Have a Cow!
Re:Jukebox Washing machine???
« Reply #1 on: February 17, 2004, 02:41:35 pm »
I like the idea, please post pics if you do go on with it!
ashardin
  • Last login:December 19, 2007, 07:43:09 pm
« Reply #2 on: February 23, 2004, 01:52:18 pm »
It would take a *lot* of work to get that thing to sound remotely listenable.
That flimsy sheet metal would rattle like hell at any sort of volume.  What you could do it take the whole machine apart, and sound dampen the hell out of the back sides (the spray type would probably be best, I'm sure there are many tight corners).  Then you would rant to internally brace that thing with wood as well.  THEN, you would need to create a sealed chamber in there designed to the t/s parameters of the subs.  Just dropping a speaker into a hole is a sure fire way to be dissappointed at the sound you get.
Sound pressure exerted by subs can be very powerful, putting a sub into something that was designed for another purpose can be difficult if it does not have structural integrity.  I've seen guys put subs into old beer kegs, that works great because they are strong, a washing machine isn't.
Don't want to discourage you from the project, but you need to think about these factors.
VMJ Team
  • Last login:July 09, 2007, 09:29:50 am
    • Virtual Music Jukebox
« Reply #3 on: February 27, 2004, 03:49:12 pm »
Check out the jukebox someone made from a refrigerator....
http://www.virtualmusicjukebox.com/gallery/detail.asp?iType=29&iPic=219
papaschtroumpf
  • Have a Cow!
« Reply #4 on: March 08, 2004, 12:24:45 pm »
I like it!, although I can see how a fridge would rattle a lot less than a washer.
