Author Topic: CRTEmudriver 2.0 Setup shows no compatible device - maybe because of AGP?  (Read 4370 times)
TGGC
  • Last login:March 13, 2019, 08:57:05 am
Hello everyone!
I have an old PC which I want to use for GroovyMame. It has Win7 64bit installed and a Radeon 3450 HD for AGP. I tried to use the CRTEmudriver 2.0 Setup, but it will not list a compatible device. The list of the device is empty. The install button is greyed out.
I suspect the AGP version of the card to be the culprit, because I have the same problem with the regular legacy catalyst drivers. They will not install. I need to use a special version, e.g. the AMD Catalyst AGP V12.6 Hotfix.
Anyone already with the same problem? Is there a known workaround to this? I would be find with using older version of CRTEmudriver or just hack ATIs drivers to manually.
Calamity
  • Moderator
  • Last login:March 24, 2026, 04:14:45 am
  • Quote me with care
Check if your motherboard needs specific drivers for the agp bus.
Steps to create a log:
TGGC
Thanks for the pointer! Motherboard is an ASUS P5VDC-MX. I could not find a driver, but there seems to be a BIOS Update:
P5VDC-MX 0810 Bios
Fix compatibiliy issue with some AMD VGA cards
Sounds like it might help, so I will try to flash the BIOS and report back.
TGGC
Ok, here are my results so far, maybe it will also help someone in future with similar problems:
The Bios Update of the ASUS P5VDC-MX was applied. It did not help with the CRTEmudriver 2.0 Setup. So I removed all ATI drivers again and pointed windows manually to the driver directory. It won't install and tell me VGA default adapter has the most recent driver. So I did the same with CRTEmudriver 1.2 and with this driver the video card is detected as an AGP Version, the driver installs, so I can use it now with Testsigning enabled. I use VMMaker 1.4 and have the desktop displaying fine on my CRT with the old 1.2 driver. The newest Groovymame starts and runs fine, but I have to see if I can make it switch resolutions, because for now it just seems to use the desktop resolution. If it does not, I think I am still fine and will just install my most used resolution and select them manually - so I am happy anyway.
The 2.0 setup still cannot find a compatible device, but I am not entirely sure if its really a bug with the detection or a problem with my somewhat broken combo of card and mobo.
Calamity
  • Moderator
Make sure to run GM with admin rights, that's probably the issue. Too bad the new drivers don't detect the card.
TGGC
I located the problem, Switchres checked only through the resolutions of the second DVI connectir and did not like any of them. Setting -screen "\\.\DISPLAY1" from command line or ini fixes this and it will pick now a 15khz modeline.
I looked through the changelists of the driver and think I will keep the old driver for now.
Calamity
  • Moderator
That driver lacks some patches like the one for forced monitor detection, but it you managed to get it working you're fine without that.
