Author Topic: Updating Groovymame, which folders do I keep from previous ver?  (Read 2661 times)
Neilalphazeta
  • Last login:May 06, 2024, 11:34:28 pm
« on: February 17, 2019, 05:31:17 pm »
I'm considering upgrading to Groovy 0206 from 0205b since I noticed no roms were rendered non working in my sets, but my concern is having to readjust all the control setups which I spent a few hours setting up for each game. Also the service menu settings as well. Does anyone know which folders contains the files that I would want to preserve to retain these?
Thank you.
Calamity
  • Moderator
  • Last login:August 29, 2026, 03:10:20 pm
  • Quote me with care
Re: Updating Groovymame, which folders do I keep from previous ver?
« Reply #1 on: February 18, 2019, 03:19:28 am »
Thank you.
The /cfg folder stores the changes you make from MAME's ui.
The /ini folder stores the ini files you create manually.
You may also want to keep the /hi folder in case you were using the hiscore plugin.
Steps to create a log:
Neilalphazeta
« Reply #2 on: February 18, 2019, 02:10:19 pm »
Thank you Calamity!
