Author Topic: Horizontal mount playing vert games?  (Read 1652 times)
Nailz
  • Last login:April 23, 2014, 08:55:03 pm
« on: February 10, 2004, 11:38:17 am »
Hey guys, I have a quick question, I know I am being paranoid, but just wanting to make sure that a 19" Vision Pro Standard Res Monitor (http://www.arcadeshop.com/parts.htm#Monitors) will be able to play vertical games with an ArcadeVGA in my new cocktail cab project as well?
Or are there recommendations on a different type of setup?
Thanks,
Marty
Cave
  • Last login:June 07, 2009, 10:27:58 am
Re:Horizontal mount playing vert games?
« Reply #1 on: February 10, 2004, 01:48:08 pm »
Yes, a vertical monitor is just a horizontal monitor on its side, the mounting brackets might be set up for horizontal fixings though, can't see this being problem in a cocktail cab.
Apollo
    • Eight Bells
« Reply #2 on: February 10, 2004, 10:26:57 pm »
Do you mean when you mount your monitor horizontally will it play vertical games as well?
If so, yes it will but you not going to enjoy them much as they will be tiny.
Nailz
« Reply #3 on: February 11, 2004, 01:37:19 am »
No, I just wanted to make sure that it would also play the vertical games in the vertical orientation without any issues....  With a cocktail table you can play from both horizontal and vertical orientation, I just wanted to double check that a horizontal mount monitor could do this ok.
