Author Topic: can i add an LED for on off to an Xin mo 1 player enconder.  (Read 1904 times)
Makavelich
  • Last login:January 19, 2019, 01:35:56 pm
« on: January 19, 2019, 12:18:09 pm »
Hello
Well the titles say it all pretty much, i own a xin mo 1 player enconder and was wondering if it is possible to and an led for on off maybe one for turbo on and off to..
my enconde is this one https://www.smallcab.net/player-joystick-buttons-arcade-encoder-pcps3-28mm-termi-p-271.html.
  • Last login:Today at 08:58:20 am
Re: can i add an LED for on off to an Xin mo 1 player enconder.
« Reply #1 on: January 19, 2019, 10:25:55 pm »
I don't see an output for a turbo indicator LED on the Xin-Mo.   :dunno
The good news is an on/off LED is very easy to add.
Pretty sure that Pin 2 on your Xin-Mo is VCC (operating voltage) -- it should be 5v, but verify with your multimeter.
All you need to do is:
- Choose an LED with known voltage and current ratings
- Enter "Source voltage" (VCC), "diode forward voltage" (LED voltage rating), and "diode forward current" (LED current rating in mA) into the calculator here to find the correct resistance and wattage specs for a current limiting resistor
- Hook it up   ;D
VCC ---- resistor ---- +LED- ---- GND
