Author Topic: aimtrack ligthgun - need to unplug to mame  (Read 5378 times)
djrino
  • Last login:April 21, 2020, 03:52:37 pm
« on: January 13, 2019, 12:47:02 pm »
Hi
i have my arcade cabinet with Maximus Arcade and 2 sticks and  6 button each, so i have installed the cpsx2 to play with time crisys with my Aimtrak Ligth Gun and all is working fine..
But when i use the MAME the stick controller not works and i need to unplug from USB my Ligth Gun.
i have tryed to do some configuration following some forum video but to work in MAME and with my arcade controls i need to unplug from usc the Ligth Gun..
With Aimtrack utility i have set it up different id but nothing change
can you give some help please
djrino
Re: aimtrack ligthgun - need to unplug to mame
« Reply #1 on: January 15, 2019, 07:25:02 am »
No one can help me??
Titchgamer
« Reply #2 on: January 15, 2019, 11:40:12 am »
What exactly is your problem?
Is it you are having to reconfigure your controls each time because the USB ID’s changing in mame?
djrino
« Reply #3 on: January 15, 2019, 12:26:26 pm »
Tnx for reply
if i unplug from USB the Ligth Gun contro come back to work..
is some about this ID but i not understand what to do..
Tnx
Titchgamer
« Reply #4 on: January 15, 2019, 01:39:19 pm »
The USB ID’s will change everytime you restart the computer or swap a USB device.
The only way to fix it is fixing the USB ID.
You can do that in mame or via a windows program.
djrino
« Reply #5 on: January 15, 2019, 02:18:37 pm »
Tnx for reply
understand, how i can do this in mame? i use mameUi
and if not work via windows program?
Tnx
Titchgamer
djrino
« Reply #7 on: January 17, 2019, 06:57:55 am »
Tnx for repy,
So on these days reading the forum you have linked i have try to do but really i bit understand ehat is to do..
do you want some my mame configuration files?
I apreciate a lot your help very very very tnx
