Author Topic: Need Advice - Adding 2 push-pull spinners and trackball  (Read 1603 times)
pixelpalace
  • Last login:December 25, 2022, 09:37:13 pm
    • Pixel Palace Arcade and Bar
« on: December 11, 2018, 02:40:23 pm »
I am trying to build out a Forgotten Worlds cabinet and need some advice on the most efficient way of hooking up two TurboTwist push-pull spinners, a track ball, 2 joysticks and 12 buttons. I was thinking of using two I-PAC 2 Interface boards. I'm not even sure if the board will recognize the push-pull spinner. Or if RetroPie will recognize it.This will all run to a Raspberry Pi.
Titchgamer
Re: Need Advice - Adding 2 push-pull spinners and trackball
« Reply #1 on: December 11, 2018, 04:23:16 pm »
Ide ditch the Pi and use a PC or you are going to be opening yaself up for one hell of a headache....
pixelpalace
« Reply #2 on: December 11, 2018, 05:48:56 pm »
Any particular reason why?
Titchgamer
« Reply #3 on: December 12, 2018, 03:40:20 am »
Combination of things.
Compatibility, Your large amount of controls, previous experience :p
Pi’s are awesome for a straight 2 player 6 button build.
You start to add extras and stuff starts to become a PITA to configure and set up.
PC is much much simpler.
