Author Topic: [Linux][SVGA 15" CRT monitor] - geometry issues on some systems  (Read 7010 times)
tiben
  • Last login:September 17, 2019, 12:54:34 pm
« on: December 08, 2018, 01:50:06 pm »
Hi,
Today i played a little with GroovyArcade 0.204 and a 15" IIyama SVGA crt monitor using the `arcade_31` monitor setting. I'm on linux using a Nvidia card.
Its works well on most systems when unsetting `doublescan`. If i set doublescan, pixels are not square, the resolution seems just wrong.
So, in this configuration, while most of the systems i tried work well, there is geometry issues in some of them. For example:
Genesis (genesis):
Resolution is good (doubled), but mame screen itself does not seems to be doubled.
Super Nintendo (snes):
Width is wrong:
C64 (c64): same as snes:
An exemple of working system (nes):
Some others systems tested with success: lresort (neogeo), punisher, sms, rtype
Here is my mame.ini:
Code: [Select]
# CORE CONFIGURATION OPTIONS
readconfig                1
writeconfig               0
# CORE SEARCH PATH OPTIONS
homepath                  .
rompath                   /tmp;/home/share/pkg/mame-roms/mame-roms
hashpath                  hash
samplepath                samples
artpath                   artwork
ctrlrpath                 ctrlr
inipath                   $HOME/.mame;.;ini
fontpath                  .
cheatpath                 cheat
crosshairpath             crosshair
pluginspath               plugins
languagepath              language
swpath                    software
# CORE OUTPUT DIRECTORY OPTIONS
cfg_directory             $HOME/.mame/cfg
nvram_directory           $HOME/.mame/nvram
input_directory           $HOME/.mame/inp
state_directory           $HOME/.mame/sta
snapshot_directory        $HOME/.mame/snap
diff_directory            $HOME/.mame/diff
comment_directory         $HOME/.mame/comments
# CORE STATE/PLAYBACK OPTIONS
state
autosave                  0
rewind                    0
rewind_capacity           100
playback
record
record_timecode           0
exit_after_playback       0
mngwrite
aviwrite
wavwrite
snapname                  %g/%i
snapsize                  auto
snapview                  internal
snapbilinear              1
statename                 %g
burnin                    0
# CORE PERFORMANCE OPTIONS
autoframeskip             0
frameskip                 0
seconds_to_run            0
throttle                  1
syncrefresh               0
autosync                  1
sleep                     1
speed                     1.0
refreshspeed              0
# CORE RENDER OPTIONS
keepaspect                1
unevenstretch             1
unevenstretchx            0
unevenstretchy            0
autostretchxy             0
intoverscan               0
intscalex                 0
intscaley                 0
# CORE ROTATION OPTIONS
rotate                    1
ror                       0
rol                       0
autoror                   0
autorol                   0
flipx                     0
flipy                     0
# CORE ARTWORK OPTIONS
artwork_crop              1
use_backdrops             0
use_overlays              0
use_bezels                0
use_cpanels               0
use_marquees              0
fallback_artwork
override_artwork
# CORE SCREEN OPTIONS
brightness                1.0
contrast                  1.0
gamma                     1.0
pause_brightness          0.65
effect                    none
# CORE VECTOR OPTIONS
beam_width_min            1.0
beam_width_max            1.0
beam_intensity_weight     0
flicker                   0
# CORE SOUND OPTIONS
samplerate                48000
samples                   1
volume                    0
# CORE INPUT OPTIONS
coin_lockout              1
ctrlr
mouse                     0
joystick                  1
lightgun                  0
multikeyboard             0
multimouse                0
steadykey                 0
ui_active                 0
offscreen_reload          0
joystick_map              auto
joystick_deadzone         0.3
joystick_saturation       0.85
natural                   0
joystick_contradictory    0
coin_impulse              0
# CORE INPUT AUTOMATIC ENABLE OPTIONS
paddle_device             keyboard
adstick_device            keyboard
pedal_device              keyboard
dial_device               keyboard
trackball_device          keyboard
lightgun_device           keyboard
positional_device         keyboard
mouse_device              mouse
# CORE DEBUGGING OPTIONS
verbose                   0
log                       0
oslog                     0
debug                     0
update_in_pause           0
debugscript
# CORE COMM OPTIONS
comm_localhost            0.0.0.0
comm_localport            15112
comm_remotehost           127.0.0.1
comm_remoteport           15112
comm_framesync            0
# CORE MISC OPTIONS
drc                       1
drc_use_c                 0
drc_log_uml               0
drc_log_native            0
bios
cheat                     0
skip_gameinfo             0
uifont                    default
ui                        cabinet
ramsize
confirm_quit              0
ui_mouse                  1
language                  English
nvram_save                1
# SCRIPTING OPTIONS
autoboot_command
autoboot_delay            0
autoboot_script
console                   0
plugins                   1
plugin
noplugin
# HTTP SERVER OPTIONS
http                      0
http_port                 8080
http_root                 web
# CORE SWITCHRES OPTIONS
modeline_generation       1
#monitor                   generic_15
monitor                   arcade_31
orientation               horizontal
connector                 auto
interlace                 0
doublescan                0
super_width               2560
changeres                 1
powerstrip                0
lock_system_modes         1
lock_unsupported_modes    1
refresh_dont_care         0
dotclock_min              0
sync_refresh_tolerance    2.0
frame_delay               0
vsync_offset              0
black_frame_insertion     0
modeline                  auto
ps_timing                 auto
lcd_range                 auto
crt_range0                auto
crt_range1                auto
crt_range2                auto
crt_range3                auto
crt_range4                auto
crt_range5                auto
crt_range6                auto
crt_range7                auto
crt_range8                auto
crt_range9                auto
# OSD KEYBOARD MAPPING OPTIONS
uimodekey                 SCRLOCK
# OSD FONT OPTIONS
uifontprovider            auto
# OSD OUTPUT OPTIONS
output                    auto
# OSD INPUT OPTIONS
keyboardprovider          auto
mouseprovider             auto
lightgunprovider          auto
joystickprovider          auto
# OSD DEBUGGING OPTIONS
debugger                  auto
debugger_font             auto
debugger_font_size        0
watchdog                  0
# OSD PERFORMANCE OPTIONS
numprocessors             auto
bench                     0
# OSD VIDEO OPTIONS
video                     auto
numscreens                1
window                    0
maximize                  1
waitvsync                 0
monitorprovider           auto
# OSD PER-WINDOW VIDEO OPTIONS
screen                    auto
aspect                    auto
resolution                auto
view                      auto
screen0                   auto
aspect0                   auto
resolution0               auto
view0                     auto
screen1                   auto
aspect1                   auto
resolution1               auto
view1                     auto
screen2                   auto
aspect2                   auto
resolution2               auto
view2                     auto
screen3                   auto
aspect3                   auto
resolution3               auto
view3                     auto
# OSD FULL SCREEN OPTIONS
switchres                 1
# OSD ACCELERATED VIDEO OPTIONS
filter                    0
prescale                  1
# OpenGL-SPECIFIC OPTIONS
gl_forcepow2texture       0
gl_notexturerect          0
gl_vbo                    1
gl_pbo                    1
gl_glsl                   0
gl_glsl_filter            1
glsl_shader_mame0         none
glsl_shader_mame1         none
glsl_shader_mame2         none
glsl_shader_mame3         none
glsl_shader_mame4         none
glsl_shader_mame5         none
glsl_shader_mame6         none
glsl_shader_mame7         none
glsl_shader_mame8         none
glsl_shader_mame9         none
glsl_shader_screen0       none
glsl_shader_screen1       none
glsl_shader_screen2       none
glsl_shader_screen3       none
glsl_shader_screen4       none
glsl_shader_screen5       none
glsl_shader_screen6       none
glsl_shader_screen7       none
glsl_shader_screen8       none
glsl_shader_screen9       none
# OSD SOUND OPTIONS
sound                     auto
audio_latency             2.0
# PORTAUDIO OPTIONS
pa_api                    none
pa_device                 none
pa_latency                0
# BGFX POST-PROCESSING OPTIONS
bgfx_path                 bgfx
bgfx_backend              auto
bgfx_debug                0
bgfx_screen_chains        default
bgfx_lut
bgfx_avi_name             auto
# SDL PERFORMANCE OPTIONS
sdlvideofps               0
# SDL VIDEO OPTIONS
centerh                   1
centerv                   1
scalemode                 none
# SDL FULL SCREEN OPTIONS
useallheads               0
# SDL KEYBOARD MAPPING
keymap                    0
keymap_file               keymap.dat
# SDL JOYSTICK MAPPING
joy_idx1                  auto
joy_idx2                  auto
joy_idx3                  auto
joy_idx4                  auto
joy_idx5                  auto
joy_idx6                  auto
joy_idx7                  auto
joy_idx8                  auto
sixaxis                   0
# SDL MOUSE MAPPING
mouse_index1              auto
mouse_index2              auto
mouse_index3              auto
mouse_index4              auto
mouse_index5              auto
mouse_index6              auto
mouse_index7              auto
mouse_index8              auto
keyb_idx1                 auto
keyb_idx2                 auto
keyb_idx3                 auto
keyb_idx4                 auto
keyb_idx5                 auto
keyb_idx6                 auto
keyb_idx7                 auto
keyb_idx8                 auto
# SDL LOWLEVEL DRIVER OPTIONS
videodriver               auto
renderdriver              auto
audiodriver               auto
gl_lib                    auto
# FRONTEND COMMAND OPTIONS
dtd                       1
Same results using "nouveau" or proprietary binary drivers.
What could be the problem ? I configured something wrong ?
By the way, what is the purpose of `doublescan` option which is set by default ? The geometry issues does not seems to occurs with it but resolutions are just wrong.
« Last Edit: December 08, 2018, 01:52:16 pm by tiben »
Calamity
  • Moderator
  • Last login:Today at 01:04:27 pm
  • Quote me with care
Re: [Linux][SVGA 15" CRT monitor] - geometry issues on some systems
« Reply #1 on: December 08, 2018, 01:58:23 pm »
Try setting aspect 4:3 in mame.ini
Steps to create a log:
tiben
« Reply #2 on: December 08, 2018, 02:24:16 pm »
Hi Calamity,
Thanks for the help.
aspect 4:3 fixes c64 and snes but not genesis:
Calamity
  • Moderator
« Reply #3 on: December 08, 2018, 02:52:40 pm »
Insert log.
tiben
« Reply #4 on: December 08, 2018, 03:01:57 pm »
Logs for "genesis sonic" bellow:
SwitchRes: v0.017l, Monitor: arcade_31, Orientation: horizontal, Modeline generation: enabled
SwitchRes: Monitor range 31400.00-31500.00,49.50-65.00,0.940,3.770,1.890,0.349,0.064,1.017,0,0,400,512,0,0
SwitchRes: xrandr version 1.6
SwitchRes: Found output connector 'VGA-0'
SwitchRes: Entering switchres_modeline_setup
SwitchRes: v0.017l:[genesis] Calculating best video mode for 256x224@60.000000 orientation: normal
SwitchRes: (   1)x(   1)_(60=60.000000Hz)
   rng(0):  512 x 448_60.000000p 31.440000 [integ] scale(2, 2, 1) diff(0.00, 0.00, 0.0000) ratio(2.000, 2.000)
SwitchRes: [genesis] (1) horizontal (256x224@60.000000)->(512x448@60.000000)
SwitchRes: Modeline "512x448_60 31.440000KHz 60.000000Hz" 20.624640 512 536 616 656 448 475 477 524   -hsync -vsync
Switchres: CRTC 0: mode 0x27f, 1280x1024+0+0.
Switchres: xrandr mode (GM-512x448_60.000000) (0x32e) 20.624640MHz
SwitchRes: Setting option -rotate
SwitchRes: Setting option -noror
SwitchRes: Setting option -autoror
SwitchRes: Setting option -norol
SwitchRes: Setting option -noautorol
SwitchRes: Setting option -keepaspect
SwitchRes: Setting option -nounevenstretch
SwitchRes: Setting option -nounevenstretchx
SwitchRes: Setting option -noblack_frame_insertion
SwitchRes: Setting option -syncrefresh
SwitchRes: Setting option -waitvsync
SwitchRes: Setting option -nofilter
Available videodrivers: x11 wayland KMSDRM dummy
Current Videodriver: x11
   Display #0
      Renderdrivers:
             opengl (0x0)
          opengles2 (0x0)
           software (0x0)
Available audio drivers:
   pulseaudio
   alsa
   dsp
   jack
   disk
   dummy
Build version:      0.204 (mame0204-dirty)
Build architecure:
Build defines 1:    SDLMAME_UNIX=1 SDLMAME_X11=1 SDLMAME_LINUX=1
Build defines 1:    LSB_FIRST=1 PTR64=1
SDL/OpenGL defines: SDL_COMPILEDVERSION=2009 USE_OPENGL=1
Compiler defines A: __GNUC__=8 __GNUC_MINOR__=2 __GNUC_PATCHLEVEL__=1 __VERSION__="8.2.1 20181105 (Red Hat 8.2.1-5)"
Compiler defines B: __amd64__=1 __x86_64__=1 __unix__=1
Compiler defines C: __USE_FORTIFY_LEVEL=0
Enter init_monitors
Adding monitor screen0 (512 x 448)
Leave init_monitors
Enter sdlwindow_init
Using SDL multi-window soft driver (SDL 2.0+)
Hints:
   SDL_FRAMEBUFFER_ACCELERATION             (null)
   SDL_RENDER_DRIVER                        (null)
   SDL_RENDER_OPENGL_SHADERS                (null)
   SDL_RENDER_SCALE_QUALITY                 (null)
   SDL_RENDER_VSYNC                         (null)
   SDL_VIDEO_X11_XVIDMODE                   (null)
   SDL_VIDEO_X11_XINERAMA                   (null)
   SDL_VIDEO_X11_XRANDR                     (null)
   SDL_GRAB_KEYBOARD                        (null)
   SDL_VIDEO_MINIMIZE_ON_FOCUS_LOSS         (null)
   SDL_IOS_IDLE_TIMER_DISABLED              (null)
   SDL_IOS_ORIENTATIONS                     (null)
   SDL_XINPUT_ENABLED                       (null)
   SDL_GAMECONTROLLERCONFIG                 (null)
   SDL_JOYSTICK_ALLOW_BACKGROUND_EVENTS     (null)
   SDL_ALLOW_TOPMOST                        (null)
   SDL_TIMER_RESOLUTION                     (null)
   SDL_RENDER_DIRECT3D_THREADSAFE           (null)
   SDL_VIDEO_ALLOW_SCREENSAVER              (null)
   SDL_ACCELEROMETER_AS_JOYSTICK            (null)
   SDL_MAC_CTRL_CLICK_EMULATE_RIGHT_CLICK   (null)
   SDL_VIDEO_WIN_D3DCOMPILER                (null)
   SDL_VIDEO_WINDOW_SHARE_PIXEL_FORMAT      (null)
   SDL_VIDEO_MAC_FULLSCREEN_SPACES          (null)
   SDL_MOUSE_RELATIVE_MODE_WARP             (null)
   SDL_RENDER_DIRECT3D11_DEBUG              (null)
   SDL_VIDEO_HIGHDPI_DISABLED               (null)
   SDL_WINRT_PRIVACY_POLICY_URL             (null)
   SDL_WINRT_PRIVACY_POLICY_LABEL           (null)
   SDL_WINRT_HANDLE_BACK_BUTTON             (null)
Leave sdlwindow_init
Enter sdl_info::create
window: using renderer opengl
renderer: flag SDL_RENDERER_PRESENTVSYNC
renderer: flag SDL_RENDERER_ACCELERATED
Leave renderer_sdl2::create
Audio: Start initialization
Audio: Driver is pulseaudio
Audio: frequency: 48000, channels: 2, samples: 256
sdl_create_buffers: creating stream buffer of 25600 bytes
Audio: End initialization
ALSA lib seq_hw.c:466:(snd_seq_hw_open) open /dev/snd/seq failed: Permission denied
Keyboard: Start initialization
Input: Adding keyboard #0: System keyboard (device id: System keyboard)
Keyboard: Registered System keyboard
Keyboard: End initialization
Mouse: Start initialization
Input: Adding mouse #0: System mouse (device id: System mouse)
Mouse: Registered System mouse
Mouse: End initialization
Joystick: Start initialization
Joystick: End initialization
Searching font Liberation Sans in -. path/s
Matching font: /usr/share/fonts/liberation/LiberationSans-Regular.ttf
Region ':maincpu' created
Region ':soundcpu' created
Region ':mdslot:rom' created
unzip: opened archive file /home/share/pkg/mame-roms/mame-roms/genesis.zip
unzip: found /home/share/pkg/mame-roms/mame-roms/genesis.zip ECD
unzip: /home/share/pkg/mame-roms/mame-roms/genesis.zip has no ZIP64 ECD locator
unzip: read /home/share/pkg/mame-roms/mame-roms/genesis.zip central directory
unzip: closing archive file /home/share/pkg/mame-roms/mame-roms/genesis.zip and sending to cache
unzip: opened archive file /tmp/megadriv/sonic.zip
unzip: found /tmp/megadriv/sonic.zip ECD
unzip: /tmp/megadriv/sonic.zip has no ZIP64 ECD locator
unzip: read /tmp/megadriv/sonic.zip central directory
unzip: closing archive file /tmp/megadriv/sonic.zip and sending to cache
Optional memory region ':tmss' not found
Optional device ':segacd' not found
Optional device ':sega32x' not found
Optional device ':genesis_snd_z80:finder_dummy_tag' not found
Optional device ':gen_vdp:finder_dummy_tag' not found
Optional memory region ':gen_vdp:palette:finder_dummy_tag' not found
Optional device ':gen_vdp:snsnd:finder_dummy_tag' not found
Optional device ':megadriv:finder_dummy_tag' not found
Optional device ':ymsnd:finder_dummy_tag' not found
Starting Genesis (USA, NTSC) ':'
  (missing dependencies; rescheduling)
Starting Motorola MC68000 ':maincpu'
Starting Zilog Z80 ':genesis_snd_z80'
Starting Timer ':md_scan_timer'
Starting Sega 315-5313 Megadrive VDP ':gen_vdp'
Starting palette ':gen_vdp:palette'
Starting Sega VDP PSG ':gen_vdp:snsnd'
Starting Video Screen ':megadriv'
Starting Speaker ':lspeaker'
Starting Speaker ':rspeaker'
Starting YM2612 OPN2 ':ymsnd'
Starting Mega Drive Cartridge Slot ':mdslot'
Starting MD Standard cart ':mdslot:rom'
Starting Software List ':cart_list'
Region ':mdslot:cart:rom' created
Attempting to parse: default.cfg
Attempting to parse: genesis.cfg
Average speed: 96.39% (4 seconds)
sdl_kill: closing audio
Sound buffer: overflows=0 underflows=2
Enter sdlwindow_exit
Leave sdlwindow_exit
SwitchRes: xrandr original video mode restored.
Switchres: xrandr error in XRRDestroyMode
Calamity
  • Moderator
« Reply #5 on: December 08, 2018, 04:39:15 pm »
Could you check if there's any genesis.ini file available for GM that might be getting in the middle?
tiben
« Reply #6 on: December 08, 2018, 05:17:09 pm »
No genesis.ini file anywere. I carefully checked, removed any other files but mame.ini in my ~/.mame directory. I changed inipath to be "$HOME/.mame" only. Issue remains.
Calamity
  • Moderator
« Reply #7 on: December 10, 2018, 01:02:00 pm »
The scale is properly calculated as it's shown in the log:
So it's either some random .ini getting in the middle or some weird problem in sdl. Just to make sure, run groovymame from command line with the option -aspect 4:3. This will override any ini contents.
If everything else fails, you have the pair of options intscalex & intescaley, that you can force either from command line or inside an ini file.
tiben
« Reply #8 on: December 10, 2018, 03:29:17 pm »
Using `-aspect 4:3` from command line does not fixes the issues (the same as in mame.ini)
If i understand the purpose of intscale(x|y) option correctly, i tried using `intscalex 2`. The screen seems now a little too wide, picture is cropped (noticeable by text in top left):
Interestingly i found the game Contra to have the "Konami logo sequence" correctly sized (test made using -aspect 4:3 only):
It seems the megadrive supports 2 or 3 resolutions. Could this be a resolution switch issue ?
The monitor does not seems to change resolution in game (changeres is set to 1)
tiben
« Reply #9 on: December 10, 2018, 03:57:39 pm »
According to Wikipedia, The genesis has two resolutions: 320x224 and 256x224.
Forcing a resolution of 640 442 (double of 320x224) now give correct picture for sonic and contra menu/in-game.
Code: [Select]
[crt@localhost ~]$ gtf 640 448 60
  # 640x448 @ 60.00 Hz (GTF) hsync: 27.84 kHz; pclk: 22.27 MHz
  Modeline "640x448_60.00"  22.27  640 656 720 800  448 449 452 464  -HSync +Vsync
and using:
Code: [Select]
modeline                22.27  640 656 720 800  448 449 452 464  -HSync +Vsync
On the other hand Konami Logo sequence seems to be at 256 224, the screen as correct aspect but pixels are not good.
Calamity
  • Moderator
« Reply #10 on: December 10, 2018, 04:08:05 pm »
Yes, now that you mention that, it's clearly an issue with in-game mode switching not working. However, your log doesn't even show a mode change during game, but maybe it's because you exited too early to catch the change. Could you confirm this by a running a longer log? I want to check whether it's sdl not being able to switch modes (I don't remember what was the current state of this as things tend to break on Linux every few months) or it's actually Swichres not catching the mode change.
In either case, you may bypass the issue by using super resolutions (set -resolution 2560x0)
tiben
« Reply #11 on: December 10, 2018, 04:24:26 pm »
Attached to this post are logs of a 5/10min run of contra
tiben
« Reply #12 on: December 10, 2018, 04:39:00 pm »
-resolution 2560x0 gives the following resutlts:
Maybe a limitation of my monitor ?
Calamity
  • Moderator
« Reply #13 on: December 10, 2018, 04:40:29 pm »
The mode switch is certainly not catched, for whatever reason. I'll need to check this. God knows how long this has been broken.
Calamity
  • Moderator
« Reply #14 on: December 10, 2018, 04:42:46 pm »
?? What resolution is it using?
tiben
« Reply #15 on: December 10, 2018, 04:51:08 pm »
About 2056x0 resolution:
About resolution switch,  maybe the mame genesis driver is broken ? I can test another driver (arcade game or other) which has resolution switch if you know one..
Thank you for your help Calamity.
**EDIT**: Maybe the strange 2056x0 ratio is a bug in nvidia binary drivers. I'll try with nouveau. However it has nothing to do with initial bug as i tried with both drivers with same results.
« Last Edit: December 10, 2018, 04:53:21 pm by tiben »
Calamity
  • Moderator
« Reply #16 on: December 10, 2018, 05:01:29 pm »
I don't understand why it picks 2560x224, while in theory you're using the arcade_31 preset. It should be scaling the vertical by 2. I'd need to see a log to figure out what it's doing.
Genesis driver is fine. It's a bug with the sdl build. Anyway the last log you posted was from Konami, not Genesis.
No, it has nothing to do with that.
tiben
« Reply #17 on: December 10, 2018, 05:21:10 pm »
command line:
./mame64 -resolution 2560x0 genesis contra &> /tmp/groovymame-genesis-contra.txt
Logs are attached.
Note: -aspect is set to 4:3. Here are the result when set to auto:
(logs are attached too)
To avoid confusion, it is the Genesis (US megadrive) game "contra" (which is a Konami game).
Calamity
  • Moderator
« Reply #18 on: December 10, 2018, 05:32:43 pm »
-aspect 4:3 is compulsory on GA due to how the desktop is configured (we'd need to set by default in the cd), so don't touch that.
I'm seeing an issue with super resolutions on Linux & 31 kHz (one case I had never tested).
By now, I believe using -resolution 2560x480 should fix it.
tiben
« Reply #19 on: December 11, 2018, 01:25:08 pm »
It is far too slow to be playable but the screen resolution is OK. My nvidia card is a PCI-e 1x, i believe this resolution is simply too high for my system.
Anyway, GM works pretty well for most of the Mame drivers i use so i'm happy with that.
By the way i can run tests to debug "in-game resolution switch" and "2560x0 resolution" issues above in Linux if it could help. Let me know.
Again thanks for your help.
Calamity
  • Moderator
« Reply #20 on: December 11, 2018, 01:57:05 pm »
Yeah, I'll let you know when I have a fix. Two bugs found in a thread, not bad  :D
tiben
« Reply #21 on: December 11, 2018, 02:47:13 pm »
haha. Where do i enter my name in the hall of fame ?   ;D
