Author Topic: Mednafen config file  (Read 4915 times)
safx
  • Last login:January 17, 2019, 05:42:23 am
« on: December 03, 2018, 10:34:51 am »
I deleted my config file for Mednafen and now everything must be reconfigured.
I believe i know how to map the buttons (ALT + SHIFT + 1 and 2 , will try that ), but resolution is another story.
How do i change resolution ? I am launching Mednafen for GENESIS/MegaDrive games through AdvMenu (GroovyArcade install).
When i boot the games, i see 25% of the total screen game (probably runnin in 640x480 and my monitor is a 15Khz 288x240)
safx
Re: Mednafen config file
« Reply #1 on: December 03, 2018, 04:56:00 pm »
Ok so i really need some pointers .
ALT SHIFT 1 does not help until i fix the resolution because i cant see the bottom of the screen where the instructions appear.
I tried to change the cfg file for mednafen
md.stretch 0, full, aspect_mult2 : any setting appears the same
md.xres 0 or 256 same thing
In my advmenu.rc i have
emulator generic "md
Calamity
  • Moderator
  • Last login:May 15, 2026, 03:21:10 am
  • Quote me with care
« Reply #2 on: December 04, 2018, 03:28:26 am »
It's been years since I tested Mednafen on Linux so I can't remember the details, but I do remember it was tricky to setup, and we did a specific Switchres ini file for it so it would work. Maybe that would be a good starting point. You should find it in the cd.
Steps to create a log:
safx
« Reply #3 on: December 04, 2018, 04:28:03 am »
I dont think i touched any switchres ini file, only the mednafen-09x.cfg (deleted and it was created again on emulator launch).
What switchres file are you talking? Thank you
alex2005
  • Last login:Today at 02:20:39 am
« Reply #4 on: December 04, 2018, 06:09:42 am »
I had the same issue and ended up playing with the screen stretching buttons in the cab, configuring the inputs, and then restoring the original screen size.
safx
« Reply #5 on: December 05, 2018, 04:53:28 am »
I fetched the mednafe.cfg file from the CD and it all worked like magic again, screen and buttons !  :applaud:
