Author Topic: Makvision D2929 pending failure  (Read 1904 times)
newmanfamilyvlogs
    • Newman Family Vlogs
« on: November 16, 2018, 08:44:20 am »
My D2929 monitor is has started occasionally making a tick noise and the screen starts to vertically collapse then snaps back full size.
Is recapping the monitor the best place to start?
grantspain
Re: Makvision D2929 pending failure
« Reply #1 on: November 16, 2018, 03:24:21 pm »
is this mounted horizontally like a normal tv or vertically?
newmanfamilyvlogs
« Reply #2 on: November 16, 2018, 04:52:09 pm »
Horizontally. It was purchased new from Happ back in 2011 and has seen moderate usage since then. Not sure if it's significant or not, but for most of that usage the brightness was turned up pretty high because it was behind tinted acrylic.
grantspain
« Reply #3 on: November 16, 2018, 06:32:27 pm »
i would look for bad solder joints, it could be a failing vertical deflection ic or a dodgy cap in the vertical or psu circuit
