Author Topic: PS4 Firmware 5.53 Causing System Failure  (Read 6059 times)
jdbailey1206
« on: October 05, 2018, 08:18:48 am »
Has anyone had problems with thier PS4 bricking after installation of firmware 5.53?  Mine did this and I thought the problem was solved with 6.00 until it bricked again yesterday.  Wondering if my hard drive is failing.  Can't imagine it would after only 2 years of intermediate use...I am going to pull out the drive and test it this weekend to see if I have a hardware issue.  Just putting out feelers to see if anyone else had this issue.
« Last Edit: October 05, 2018, 10:18:10 am by jdbailey1206 »
Titchgamer
Re: PS4 Firmware 5.53 Bricking Console
« Reply #1 on: October 05, 2018, 09:41:52 am »
What do you mean by bricked?
As my definition of bricked is unfixable paper weight!
jdbailey1206
Re: PS4 Firmware 5.53 Causing System Failure
« Reply #2 on: October 05, 2018, 10:18:36 am »
Better?
  • Last login:May 15, 2026, 05:08:29 pm
« Reply #3 on: October 05, 2018, 10:23:11 am »
My first PS4 would glitch out and crash whenever I played Bloodborne or got on the little helicopter in Far Cry 4.  I made up a fake invoice from Amazon and sent it in for a warranty repair.  Been fine for years afterwards (and they did actually repair it.... was hoping for a replacement but oh well).
Titchgamer
« Reply #4 on: October 05, 2018, 12:36:20 pm »
Better?
Not really still the same on my phone :p
My HDD has never failed in my PS4 and its had pretty heavy use since I got it however many years ago.
It is getting noisy however so may well fail soon....
However like I said depending on what you mean by bricked it could be a few things.
Have you noticed the fans kicking in or working harder than normal?
Overheating is a pretty common cause of problems and if lucky can be fixed by a good clean and hoovering.
Failing that its a re-ball.
jdbailey1206
« Reply #5 on: October 05, 2018, 01:54:07 pm »
...fixed by a good clean and hoovering.
What good would cleaning it, putting a bug inside and then making it cross dress do?
Titchgamer
« Reply #6 on: October 05, 2018, 03:08:47 pm »
Ule have to explain that one....
*confused.com*
jdbailey1206
« Reply #7 on: October 05, 2018, 03:51:52 pm »
You said hoovering it.  It was a play on words.  You meant vacuuming and I skewed it and referenced J Edgar Hoover who was the head of the FBI from '24 to '72.  He allegedly used to cross dress and bug everyone of any significance to get the goods on them and use it as leverage.
Titchgamer
« Reply #8 on: October 05, 2018, 04:54:10 pm »
Ahh right.
That makes some sense!
