Author Topic: R-85 Records skipping  (Read 4247 times)
gagsenior
  • Last login:November 05, 2018, 07:05:20 am
« on: October 02, 2018, 11:40:39 am »
Hi,
Newbie to site and juke boxes
I have an R-85
Some records (few) play fine.
Others load and start but just skip and they have to be rejected..
Replaced the needle and adjusted the arm but still have problems.
can someone help me out...
thanks,
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
Re: R-85 Records skipping
« Reply #1 on: October 04, 2018, 08:47:25 am »
Hello,
Sorry you did not leave a name.
You need to check and adjust the tone arm cam adjustment, if you have a R-85 manual look at page 22 fiure 9, this involves adjustment of the cam collar (part number 2-18133-01)
Regards
Alan
Alan Hood
ami-man
UK
gagsenior
« Reply #2 on: October 04, 2018, 03:37:55 pm »
Alan,
thank you for the reply...
I will try that this weekend..
If it does not work i will post again...
Again thanks for your help.
Paul
gagsenior
« Reply #3 on: October 15, 2018, 04:58:27 pm »
Alan,
i tried to adjust as per your instructions..
Unfortunately at this time the carousel just turns and will not pull a record to play.
I obviously created another problem.
I did adjust the arm but I am not sure if I fixed that problem because of the new problem...
What did i break ???
ami-man
« Reply #4 on: October 19, 2018, 08:05:18 am »
Hello Paul,
The new problem more than likely is dry joints on the header pins on the boards or loose connections on the looms.
Regards
Alan
Alan Hood
ami-man
UK
dandylion35890
  • Last login:December 13, 2018, 10:42:16 am
« Reply #5 on: December 13, 2018, 08:05:57 am »
Ami Rowe AMI R-85 starlight Jukebox selects record tries to play the record then cancels. Tries to play the same record again then cancels. keeps doing this each time.
I switched off the jukebox switched it back on again I then select a different record.
The carousel stops, the record is selected placed on the turntable and the same thing happens again!
It tries to play record then a second later picks up the record puts it back into the carousel and re-selects it. Once more it tries to play again and back to the same problem and so on!
Can anyone provide me with the answer to this problem, please? Many thanks, Les.
ottervswolf
  • Last login:February 11, 2019, 12:48:37 am
« Reply #6 on: December 29, 2018, 08:31:25 pm »
I have this saaaaaaame problem on my R85.
It was working flawlessly until I switched it on and it's doing this now. I have zero clues on how to fix this.
Seriously need help.
