Author Topic: Inside pin will not reset on 1965 Rowe 200  (Read 2051 times)
fatcatken
  • Last login:October 02, 2018, 12:05:29 pm
« on: September 30, 2018, 02:45:59 pm »
I have a 1965 Rowe 200 jukebox that does not reset the pin on the inside of the Farris wheel.  The outside works fine.  I have the service manual and find it very difficult to follow, it is complete but the schematic is fragmented and hard to understand.  This problem started out of the blue, was working fine, the next time maybe a month later not working.  Have checked the cam switches and the stop switch all seem fine.
Any ideas would be greatly appreciated.
Thanks in advance, fatcatken
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
Re: Inside pin will not reset on 1965 Rowe 200
« Reply #1 on: October 01, 2018, 08:57:06 am »
Hello fatcatken,
If your jukebox is the 1965 Rowe Ami Model N Diplomat.
I would remove the search unit and check that the open relays S1 & S2 contacts are clean and well adjusted, you can clean the tips of the contacts by pulling a paper taper between the contacts.
Remove the stop plate assembly and check the miscrswitches that locate the pins and reset them.
Regards
Alan
Alan Hood
ami-man
UK
fatcatken
« Reply #2 on: October 02, 2018, 12:05:29 pm »
Thanks AMI Man, cleaned the relay contacts as you suggested and it works fine.  I really appreciate your help.  Keep up the good work...
fatcatken
ami-man
« Reply #3 on: October 04, 2018, 08:59:11 am »
You are welcomed.
Regards
Alan
Alan Hood
ami-man
UK
