Author Topic: Cheap and easy way to mount boards  (Read 4405 times)
thebrokenjoystick
  • Last login:December 01, 2018, 08:23:18 pm
  • The cake is a lie
    • My Vogon Poetry
« on: August 28, 2018, 10:18:31 pm »
Maybe this has been posted before, if so, sorry for the dupe...
Working on my icade->Retropie project and needed a cheap and easy way to mount the monitor driver boards. Went to the local Dollar tree to see if I could make something work and came across these command strip knockoffs - 9 for $1 and they work perfectly. I took off the command strip and just used hot glue instead. Cheap and easy.
05SRT4
  • Check out my Pow Pow
Re: Cheap and easy way to mount boards
« Reply #1 on: August 29, 2018, 05:03:31 am »
Good Idea and thanks for sharing. I usually get some nylon washers from the hardware store and use screws. If really cheap and dont want to go to the store ill cut up a old BIC pen and use those as the spacers.
thebrokenjoystick
  • The cake is a lie
    • My Vogon Poetry
« Reply #2 on: August 29, 2018, 09:28:38 am »
Wow - those are great ideas too! Thanks!
barrymossel
  • Last login:October 29, 2021, 11:25:52 am
  • Spectrum
thebrokenjoystick
  • The cake is a lie
    • My Vogon Poetry
« Reply #4 on: August 30, 2018, 11:22:08 am »
