Author Topic: static vmmaker table + GROOVYMAME/MAME?  (Read 5121 times)
purity1516
  • Last login:May 28, 2019, 04:32:32 pm
« on: August 24, 2018, 07:16:37 am »
Hello everyone!
I am currently using several standalone console emulators plus GM.
As far as I know, most emulators do not support vmmaker's dynamic table to manage refresh rates.
So in that scenario, I suppose the best approach would be the static table, right?
In that case, how can I configure GM to properly deal with the refresh rates? Or should I use regular MAME with some special configuration?
R-Typer
  • Last login:September 09, 2024, 12:50:41 pm
  • C64 Rulez!!!!
Re: static vmmaker table + GROOVYMAME/MAME?
« Reply #1 on: August 24, 2018, 09:16:48 am »
I also use dozen of emulators on my crtemu setup with static mode in vmmaker enabled. Yes, you have to have static mode enabled for multiple emulators that is correct, but it wont change behavior of groovy mame. it will work as intended in both static and dynamic mode.
