Author Topic: Export from Sketchup to Gimp????  (Read 4392 times)
FALSE
  • Last login:February 25, 2024, 08:13:59 pm
« on: August 22, 2018, 11:07:20 pm »
This is probably a stupid question but I'm trying to fumble through some art.
I've modeled my cab in Sketchup.
Is it possible to export just like the side panel shape and get it into Gimp so I have a full size image of my cabinet panel to work with?
barrymossel
  • Last login:October 29, 2021, 11:25:52 am
  • Spectrum
Re: Export from Sketchup to Gimp????
« Reply #1 on: August 23, 2018, 03:54:21 am »
I struggled with that as well at first. What you should do is right click on the surface you want to focus on for your 2D and choose align view. Then choose export as 2D (not sure if this is possible without the Pro version of Sketchup) and find export as PDF (from top of my head) so dimensions will stay as is (always check on dimensions in a later phase - might be one of the other file types that kept the dimensions). Then import in Gimp or a vector based program.
Might not be the exact steps, as it's from top of my head, but you should be able to manage with this I guess.
FALSE
« Reply #2 on: August 23, 2018, 09:19:21 pm »
Thanks, looks like the free version isn't compatible unfortunately.
barrymossel
  • Spectrum
« Reply #3 on: August 24, 2018, 05:20:26 am »
You can download Pro as a 30 day trial as far as I know. It is fully functional!
FALSE
« Reply #4 on: August 24, 2018, 08:46:44 pm »
I will look into that. Thanks again!
