Author Topic: Sync issues on Nanao MS9-29 + JPAC  (Read 2399 times)
Mufti
  • Last login:October 25, 2020, 05:50:07 pm
« on: August 07, 2018, 03:02:42 pm »
Hi there.  I'm having difficulty getting the 'Nanao MS9-29' specific settings working wth a JPAC.   When using the 'Nanao MS9-29' setting; the JPAC does not display a sync light or picture.  I'm able to use the 'Arcade 15.7 kHz - standard resolution' monitor type just fine.
AMD A10-7860K with Radeon R7
I'm using standard user_modes.ini, as I don't know how super resolutions work.
I've tried using composite sync (and updating the monitor polarities and regenerating/installing modes, and that gives me a sync light (yellow) but no picture.
Desktop resolution set to 640x480 60i.
I feel like I'm missing something obvious.  Could anyone point me in the right direction?
« Last Edit: August 07, 2018, 03:39:31 pm by Mufti »
Sledge
  • Last login:July 24, 2025, 09:26:13 pm
Re: Sync issues on Nanao MS9-29 + JPAC
« Reply #1 on: August 07, 2018, 09:37:04 pm »
You are supplying the JPac with power? (been there done that once before)
Have you discovered whether you've got an auto switching Nanao or not? (15/25)
if not edit out the 25kHz line.
Set the JPAC to 15kHz?
post up your ini files too..
Are you able to manually change to a low resolution at all, and have it display on the screen?
« Last Edit: August 08, 2018, 08:22:41 am by Sledge »
krick
  • Gotta have blue hair.
« Reply #2 on: August 08, 2018, 12:58:49 am »
You should be using the latest version of GroovyMAME along with CRT Emudriver & CRT Tools 2.0 beta 13 (Crimson 16.2.1 for GCN* cards) for Windows 7/8/10 64-bits...
http://geedorah.com/eiusdemmodi/forum/viewtopic.php?id=295
...and you should follow the guide here and install super resolutions...
http://geedorah.com/eiusdemmodi/forum/viewtopic.php?pid=1052#p1052
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
Calamity
  • Moderator
  • Last login:July 19, 2025, 04:03:33 am
  • Quote me with care
« Reply #3 on: August 08, 2018, 03:38:34 am »
Just use te arcade_15 preset. The ms929 preset was created to make use of the 24 kHz range, but this only works for the autoswitch model.
However, in this case it's the JPAC the one that doesn't like the signal, probably 24 kHz. To properly diagnose this you should be able to tell which frequency is being sent to the JPAC at each moment, by looking at the video mode that's being used. Once you know that, you could adjust the range until both the JPAC and the monitor are happy. But anyway, I wouldn't bother, unless you are sure you have the autoswitch chassis.
Steps to create a log:
