Author Topic: DOS and Boot with 15khz Arcade Monitor  (Read 1501 times)
daeven
  • Last login:July 15, 2022, 12:17:33 pm
  • Llama this!
« on: February 05, 2004, 01:05:38 pm »
I've been reading up on AdvanceMAME, and I still don't see how it can be done.  I need to set up a standard arcade monitor on a PC without an ArcadeVGA.  Can it be done without having to wait to switch on the monitor after the 'vga' command is run in the autoexec.bat file?
I am trying to set this thing up as a DOS-based system.
Can Scitech Display Doctor change the 'boot mode' to use a 15khz signal?  Is there some other way to do this?
menace
Re:DOS and Boot with 15khz Arcade Monitor
« Reply #1 on: February 05, 2004, 02:08:59 pm »
I originally ran advancemame on an arcade monitor--I used to start both the pc and the monitor at the same time--there was some garbage on the screen for a second or two (bios screens) but then once the 15khz driver flicked on it was good.  for some good instructions go here: http://www.mame.how.to/
or here:
http://easymamecab.mameworld.net/
daeven
  • Llama this!
« Reply #2 on: February 05, 2004, 03:03:51 pm »
I'm not too worried about the appearance of the garbage, I'm just wondering if this will be harmful to the monitor.
menace
« Reply #3 on: February 05, 2004, 04:08:56 pm »
I was told that overtime it would wear on some components but only slightly more than having a stable signal--from then on, I just left it off until I heard an audio cue I had inserted when the 15khz program had started.  Not a big deal either way.
